Timing cover
Old Aug 13, 2017 | 11:06 PM
07 V-MAX's Avatar
Default Timing cover
I have a 2007 GMC VortecMax 6.0L that I'm changing cam, timing gears and chain...the gear was a single bolt but is now a 3 bolt solid gear...do I have to change the timing cover due to difference in sensor position?
Old Aug 13, 2017 | 11:13 PM
FFDP's Avatar
You need to buy the correct cam gear that is still a 4x.
The timing cover stays the same.
Old Aug 13, 2017 | 11:15 PM
07 V-MAX's Avatar
It is the gear set that goes with the new cam from Summit...
Old Aug 13, 2017 | 11:17 PM
FFDP's Avatar
If the gear is a 4x 3 bolt cam gear, then you can use it.
Otherwise a 1x cam gear won't work in a GEN 4 motor because the cam sensor won't work with it.
Summit sells a million different cam combo's, so I have no idea what you bought.
Old Aug 13, 2017 | 11:24 PM
07 V-MAX's Avatar
I think it is but I'll have to check and see...thanx for your help bro! I may get back to ya tomorrow.
