Tick Tick Tick... Injector or lifter?
#23
I agree with the head bolt suggestion. Here is my parts list.
Ls7 lifters - 12499225 - $104.00
Comp Cams Pushrods 7.4” - 7955 - $135.35
LS6 valve springs - 12499224 - $49.92
Head Gaskets - 12498544 - $26.00
AIR tube gaskets (2x) - 12553617 - $1.00
Water pump gaskets (2x) - 12559271 - $2.52
front engine seal - 12561244
ARP Head Bolts - 134-3610 -$113.95
I found the head gaskets but I don't know if they are the MLS type so hopefuly I can find out and order everything this weekend.
#24
Don't buy your pushrods until you can verify on YOUR engine what the correct length will be. I ended up using .100 shorter than stock in mine. That was with cam and spring swap only, no changes to heads or gaskets.
This summer I had the transmission oil pump break. It sounds very much like an exhaust leak. Until you put your ear on the tranny pan.
Pontiac Derek
09-19-2015 01:49 PM
