Thrust bearing, crank play 3/16" of play
Old Feb 10, 2013 | 10:23 PM
silverado2000's Avatar
Default Thrust bearing, crank play 3/16" of play
I pulled my motor because it was untuneable, now that i have it down to the short block i noticed the crank has about 3/16 of an inch play sliding in and out. Im wondering if you guys think the thrust bearing went bad?
Old Feb 10, 2013 | 11:53 PM
smokeshow's Avatar
Mod with training wheels
Is there **** in the pan? If its out, you can just pull the pan and look at the bearing.
Old Feb 11, 2013 | 12:14 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Yes. But they don't usually just go bad for no reason. Did you balloon a converter?
Old Feb 11, 2013 | 01:37 AM
stock48's Avatar
9 Second Truck Club
Measure it with a dial indicator. Normal is .004~.008'', If over .020'' there is serious probs. .010'' of thrust can feel like a lot more than it actually is.
Old Feb 11, 2013 | 08:18 AM
I'm gonna pull the pan today, the motor getting some forged parts, cam, heads for the turbo build I'm doing now. I just wanted to see if my unstable oil psi, and crazy KR could be from a bad thrust bearing. I will make sure to post up what I find in the oil pan latter. And about ballooning the converter this whole problem started at 1500 miles after putting the motor in I got on it and it feel on its face and never ran right again. O well going FI now already have the turbo Kit, 4l80e, and a few other goodies just hoping I have better luck this time.
Old Feb 11, 2013 | 08:25 AM
sand man's Avatar
not a pro builder but Iv had my share, if the play is truly 3/16 the thrust bearing is f**ked
Old Feb 11, 2013 | 08:26 AM
sand man's Avatar
good luck
Old Feb 11, 2013 | 09:28 AM
2doorfury's Avatar
I bought my 6.0 with 150k miles on it. Owner said it had low oil pressure, after i tore it down and inspected it, i found the thrust bearing was destroyed. Also destroyed the crank too. Had to buy a new crank. But there was also about 3/16 play, probably even more..make sure it didnt dig a groove in the crank where the thrust bearing rides. If so, you need a new crank
Old Feb 11, 2013 | 10:05 AM
if it did I guess I'm just gonna have to build a 408
I'll post pictures of what I find tonight.
Old Feb 11, 2013 | 01:45 PM
2doorfury's Avatar
Gives you more of a reason too! Go for it.
