Throttlebody bypass
Old Aug 13, 2005 | 05:32 PM
gobblergetter's Avatar
Default Throttlebody bypass
What does this mod do? What all is involved in doing it?
Old Aug 13, 2005 | 05:37 PM
white1's Avatar
It re routes the coolant so it doesnt go thru the tb so you get a cooler intake charge. All thats involved is re routing the coolant hose and plugging the lines going into the tb.
Old Aug 13, 2005 | 07:38 PM
4.8 stocker's Avatar
is there a thread that has indepth pictures/steps kinda like a tech article????
Old Aug 13, 2005 | 07:51 PM
budhayes3's Avatar
PT's Slowest Truck
Here's a link to ls1howto.com I believe the write up is for an f-body, but it's basically the same thing.
Old Aug 13, 2005 | 07:53 PM
mason110's Avatar
just take the two hoses that go in and out of the bottom of the throttle body and hook them together with a barbed union i think its 3/8 but not sure. Basically just by pass the throttle body.
Old Aug 14, 2005 | 04:55 AM
therock's Avatar
Default If You Live In A Hard winter Area...
...you may want to be aware in winter after shut down condensate will form and if parked long enough it will freeze. The newer motors have a tilted TB to avoid this also. You may want to run it in winter.
Old Aug 14, 2005 | 05:22 AM
I agree with therock, it got down to 40ish the other night after my truck sat in my driveway for a longass time, when i left home at 6am when the sun was just starting to comeout, i would have to mash the throttle a couple of times after i initially started it up because it had the tendency to stick shut. Kinda sucks, but it takes like 5minutes to bypass and 5 minutes to undo the bypass so when late fall/winter comes just switch it back.
Dave
Old Aug 14, 2005 | 09:54 AM
budhayes3's Avatar
PT's Slowest Truck
Dave
This is good info...I've considered doing this mod a few times, but haven't been able to decide if it would be worth it to me. Winters in Jersey can get down to and below 0* so if I do decide to do it, it will be one of those summerize items.
Old Aug 14, 2005 | 12:56 PM
desrtrat's Avatar
i did mine about 2 yrs. ago, when i was living in N.Y. and never had any problems with iceing, on start up, or while driving. im also running the volant with ram air tube.
on sticking tb. 40* should not be cold enough to form ice, maybe just a good cleaning will take care of it ??
Old Aug 14, 2005 | 01:02 PM
TXsilverado's Avatar
its 3/16"
