Throttle Body Swap
Old Feb 10, 2007 | 10:41 AM
l_kusler's Avatar
Default Throttle Body Swap
I have a 4bolt LS2 90mm style factory throttle body, and an 03 vortec engine with the stock 75mm 3 bolt. I've built an adapter plate out of aluminum to fit it up to the manifold but my question is can the 6 pin connector on the 90mm unit be adapted to function on the stock 8pin connection of the truck unit. They are obviously both ETCs. Someone has had to done this with a head, intake manifold and tb swap on their truck?! Any info or advice will be greatly appreciated!
Thanks in advance,
Lyndon
Old Feb 10, 2007 | 10:53 AM
Stoichiometric's Avatar
There is a harness available to make that work, you may also need a tach module. Call Richard at West Coast Cylinder Heads, he has the parts you need. You can find his website from the list of Sponsors on the right>
OHsixLS3
Dec 27, 2016 09:30 AM
jdb11386
Dec 3, 2015 09:34 PM
Slammed96
Jul 27, 2015 07:22 AM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
