Throttle body spacer problems
Old Sep 14, 2007 | 09:28 AM
Biggin's Avatar
Default Throttle body spacer problems
I have a cold air intake on my 2003 chevy and i just bought a throttle body spacer an when i put it on my intake tube is hiting my fan.
Old Sep 14, 2007 | 09:39 AM
99Silverado5.3's Avatar
Go back to stock intake or take the spacer off or get electric fans.
Old Sep 14, 2007 | 09:44 AM
I hate to tell you this, but that's a common problem and if you want it to fit you have to modify the hell out of a bunch of ****.
Really....you spent money for a spacer that does absolutely nothing unless you use it as a nitrous plate. Seriously....they add 0 torque and 0 horsepower.
Old Sep 14, 2007 | 09:50 AM
Tootall's Avatar
the spacer is useless unless you have lines hooked up to it.
Old Sep 14, 2007 | 09:55 AM
Quik's Avatar
5 year bitches!
sell the spacer, if you want the whistle sound get a turbo, if you want gas mileage get a tune...if you want performance buy performance mods
Old Sep 14, 2007 | 09:58 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yup, sorry. The TB spacer does nothing for a port injected engine except elongate the intake. If you plan on running N2O then it can be drilled and tapped but otherwise useless.
Old Sep 14, 2007 | 10:02 AM
Throttle body spacer is the best mod I've done so far, call nitrous outlet... Dave will set you up fat.
Old Sep 14, 2007 | 03:09 PM
stovall07's Avatar
Registered User
yeah i have a TB spacer on my intake but that was required for the TB i'm running. i've got a 85mm TB and it's so much larger than stock that i had to have a spacer but it does nothing but whistle. later on i plan on porting it for nitrous but other than that, pointless.
Old Sep 15, 2007 | 04:26 PM
bgray's Avatar
TOTM: June 2007
jsut cut the fan shroud...no biggie...or throw the spacer in the trash
Old Sep 15, 2007 | 04:59 PM
ZZebes's Avatar
the best thing to do with that spacer is huck it at a squirrel and make a cool whistle sound in the process
