For those with under drive Pulleys
Old Jun 11, 2003 | 09:12 PM
homeskillet's Avatar
Default For those with under drive Pulleys
when you put on your new pulleys did you have to get a larger belt or can you keep you stock on? just want to know ahead of time.
Old Jun 11, 2003 | 09:26 PM
CashDudeHomie's Avatar
Default Re: For those with under drive Pulleys
You need 2 new shorter belts. There are 2 different accessory belts depending on which alternator pulley you got or if you are leaving the stock one. There is only one AC belt though. Look on aspracing.com for the belt numbers.
Old Jun 12, 2003 | 02:18 PM
abbo7's Avatar
I am sure that this has been brought up before so you can direct me to a link if it has, but would you run into problems using a underdrive/lighter pulley? Wouldnt the crank on a V-8 need to help be balanced and dampered with the stock "heavier" pulley? Assuming the stock pulley is a harmonic balancer. Just wondering if anyone has run into problems using an aftermarket pulley for extended periods of time.
Old Jun 12, 2003 | 05:21 PM
well the asp pullys i have seen have harmonic balancers on them. see i only have the v6 but they still make pullys for my truck.
Old Jun 12, 2003 | 07:28 PM
eallanboggs's Avatar
Judging by the surface of the metal of the factory pulley I'd say it's a cast unit, probably iron. I wouldn't go so far as to call it a harmonic balancer. I think that's an overly generous characterization. It's more like a PTO on a tractor. It just gives you a place to mount a belt to drive the paracitic devices like the power steering, fan, alternator, A/C, etc. Don't forget the flywheel and pressure plate which are quite heavy help to smooth out the power pulses somewhat while the autos have their torque converters full of fluid which do the same thing. The ASP pulley is a much better designed and finished unit. It looks like CNC billet aluminum. It's high quality.
thunder550
Oct 8, 2015 04:53 PM
chevysten
Aug 13, 2015 07:36 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
