which thermostat?
You should probably wait till you are more heavily modded to worry about the thermostat... it's really a fix for guys that have really changed alot of stuff and are having trouble keeping the temps down. If you lower the temp that the thermostat opens, you really aren't accomplishing much b/c it will take forever for the the computer to go into closed loop - and when you are in open loop, the truck is in 'safety mode' until it reaches operating temperature.
Originally Posted by Black Iced 02
so are you saying that a person like myself would really not benifit from having a 180 stat?
Before...typical WOT detonation from HPP-3 tune, not able to break tires loose from start without brake stall.
After...no detonation at all at WOT, now able to spin tires for several seconds from start with no brake stall.
I changed to a 160 degree t-stat last weekend. My temp gauge now sits right on 180 at operating temp. It takes about three minutes to fully warm up from a cold start. Temps in S. Fla have been in the mid-90s since I installed it. I believe that a noticeable difference will be realized in warmer climates with a cooler running engine. My engine is definitely making more power running at 180 degrees than at 210 degrees. I'm leaving today for a 1,500 mile round trip over the next week and will see if it has made any difference in fuel economy.
The only comment I have after making the change is that I would like to have the GM bean counter by the gonads who decided to save $1.50 by eliminating the radiator drain valve so I could make him feel about the same as I did when I had to remove the lower radiator hose and let two gallons of DEXCOOL pour all over me.
I run a hose off the drain
Instead of the core support filling up with coolant and dripping in 300 different places.
I also will be changing to a 160 and a 34 in rad - I will have Allen reshoot my PCM
Originally Posted by LS1csherm
The rad petcock is on the left side of the rad.
I have a 160 and have verified this with EASE.
If you go with a cooler thermo, just get the 160. It runs at about 172 cruising, and gets a little hotter in stop and go traffic.
