Is there a 150A or 200A Alternator for our trucks?
Old Dec 8, 2003 | 08:24 AM
14 Second Truck Club
Default Is there a 150A or 200A Alternator for our trucks?
I was just wondering if there was a 150A or 200A Alternator for our trucks? If there is, will it just bolt-up with no problems? Also, would it have a negative effect on anything? Where could I find one and how much?
Thanks in Advance!
Old Dec 8, 2003 | 11:08 AM
Hit Man X's Avatar
Yes there are. Alterstart@aol.com sells 'em...$250 I suppose. It's the larger case so you will need a longer belt.
Negative effects? Nope, only more amperage!
Old Dec 8, 2003 | 12:28 PM
"It's the larger case so you will need a longer belt."
So, I couldn't use the belt that comes with the ASP Crank Pulley? Would a longer belt be needed with the 130A?
Thanks
Old Dec 8, 2003 | 01:32 PM
Hit Man X's Avatar
Thanks
Yes if you compare the stock 105A vs the stock 130A alt's, the 130A has a larger case and needs a longer belt. It sucks that you have to shell out another $25-30 for a belt.
Old Dec 8, 2003 | 02:16 PM
Hit Man X: I e-mailed that address and here is what they said:
"We have a 200amp $249.99 plus S&H no longer belt needed but you will have to upgrade the recharge cable to 4 guage."
How much would that cost (Parts & Labor)?
Is it worth going through all this hassle? So, its a definite YES that I will have problems if I have a crank pulley and electric fans and don't upgrade my alternator?
Old Dec 8, 2003 | 02:40 PM
1BADHD's Avatar
Nope no new belt needed. They use the 105 amp case with beefy internals. I use mine with the ASP pulley. To get full affect out of it you will need to up your idle 100 rpm. That is if you use it with the ASP pulley. It already comes with a overdive pulley. You dont need a bigger gauge cable unless your using it to full capacity. i dont know if that is possible. 200 amps is alot. Anymore questions, PM me.
Old Dec 8, 2003 | 02:41 PM
Hit Man X's Avatar
S&H will be like $25 as that thing is heavy. I HAD to get a longer belt when I got my 130A alt. PM or IM 1BADHD he got one of their 200A units.
You can get 4awg cable for like $1/ft and make your own but still need a fuse/fusable link.
YES, it is worth the hassle. Low charge at idle sucks, your fans pull slower, A/C blows slower, headlights are dim, etc. I just upgraded my 130A on my F-150 to a 200A unit due to electric fans...
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
Nimoryan
Jul 5, 2015 03:50 PM
