thanks
Old Feb 22, 2003 | 07:27 AM
typhoon186's Avatar
Default thanks
Thanks for the info.
I think I'm leaning towards some nitrous. What's the best kit to get? Wet or dry? What safety features?
Thanks again,
Jim
Old Feb 22, 2003 | 09:17 AM
parish8's Avatar
single digit dreamer
Default Re: thanks
there are lots of kits and they are all good. i like the NX wet kit, 35-150hp. from what i have seen you can spary a 100 shot all day long. most people get away with a 125shot, the 150shot is where the problems start.
since you have a 6.0 that will be using a little more fuel for itself i think i would stick with a 100shot.
how much money do you want to spend? you can spend $500 and just go with the basic kit and most likely be fine with a 100shot for a long time.
you can spend $1200+ and spray a 150shot(safely, in my oponion). nx kit, genx accesory kit, window switch, fuel presure gauge, inline pump.
a 100shot wouldn't kill your tranny nearly as fast as a 150shot.
Old Feb 22, 2003 | 10:07 AM
BigTex's Avatar
Default Re: thanks
If you spray a 100 shot off the line, it hits like a ton of bricks. If you spray in the upper rpms, its not so much of a shock.
