Temporary CAI, made from spare parts...
Old Mar 17, 2006 | 02:41 PM
SS_bnoon_SS's Avatar
Default Temporary CAI, made from spare parts...
When I get my electric fans installed sometime later this spring/summer, I'll make a custom full CAI and heat shield, but this will do for now. I used one of the mandrel bends that I bought for the CAI I'll build later and a couple of rubber connectors that I had from a previous CAI experiment (I'll use 3.5" silicone couplers for the final version). Once the fans get put in, I can replace the factory plastic piece (which is the most restriction in the factory intake IMO). The filter is a 12" long S&B powerstack from EBay for $22 shipped new.
I also made a velocity stack since I couldn't find one locally in the 6.25" to 3.5" size that I wanted to use. I cut a small length of 3.5" pipe, welded on a 6.25" circle, then used Pi x R squared to figure circumference and trimmed, then rolled a 2" wide strip to make the 6.25" diameter pipe for the filter to bolt to. I stretched a T-shirt around the 6.25" side, held in place with a worm clamp, then pushed it down into the 3.5" side using a circle of wood 3.25" in diameter (from a hole saw)... then coated it with fiberglass resin... confusing in words, I know... anyway, here are the pics...
It's a nice seat of the pants gain, especially above 3500 RPMs. It's like there's a secondary system that kicks in...
Old Mar 17, 2006 | 02:51 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Looks good wanna make me one?
Old Mar 17, 2006 | 03:04 PM
Midnight's Avatar
VTEC SILVERADO SS wOwZeRs!!!
Looks good, I did about the same thing on my truck at one time.
Old Mar 17, 2006 | 03:11 PM
Sure, let me scrounge up some more plumbing parts from the high performance mecca that is Home Depot... For a temporary test, this provided quite a gain by the butt dyno (recently calibrated by the way). I can't wait to get the plastic part replaced...
Old Mar 17, 2006 | 03:18 PM
Midnight's Avatar
Yeah do what I did and just get a smooth tube from the TB to the MAF, I got an air raid intake tube for mine. That is all you'd need, probably flow the same as an aftermarket intake.
Old Mar 17, 2006 | 03:43 PM
Even better... the mandrel bend you see in the pic is a 3.5" piece from Ebay for $8 each... Once I get the electric fans on there, the stock plastic piece is gone.
Old Mar 17, 2006 | 03:52 PM
Zick's Avatar
Looks good, thats kind of what I had in mind of doing. Just running the pipe down to a filter under where the airbox sits.
Vortec350ss
Jan 12, 2016 10:36 PM
cheyenne383
Nov 13, 2015 09:24 AM
Velocity1
Oct 2, 2015 08:01 AM
The_W
Oct 1, 2015 02:35 PM
