<TECH ONLY> Proven Peformance Packages! Naturally Aspirated GM
Old Dec 2, 2006 | 12:57 PM
TurboGibbs's Avatar
Default <TECH ONLY> Proven Peformance Packages! Naturally Aspirated GM
YEAR, MAKE, MODEL:
ENGINE SIZE:
POWER ADDER SPECIFICS(IF APPLICABLE):
HEADS:
COMPRESSION RATIO:
CAMSHAFT SPECS:
VALVE TRAIN(PUSHROD LENGTH, ROCKERS ETC.):
INTAKE MANIFOLD & TB:
FUEL SYSTEM:
EXHAUST:
TRANSMISSION & STALL/CLUTCH:
REAR GEAR & TIRE SIZE:
SUSPENSION/TRACTION:
TRUCK WEIGHT(ASSOCIATED WITH ET):
RWHP/TQ:
1/4 & 1/8 MILE TIME AND MPH:
Copy, paste, and fill in the blanks!
Old Dec 2, 2006 | 09:52 PM
stone150's Avatar
YEAR, MAKE, MODEL: 01, chevy silverado z71
ENGINE SIZE:5.3 (325)
POWER ADDER SPECIFICS(IF APPLICABLE):N/A
HEADS:stock
COMPRESSION RATIO:stock
CAMSHAFT SPECS:stock
VALVE TRAIN(PUSHROD LENGTH, ROCKERS ETC.):stock
INTAKE MANIFOLD & TB:stock & stock (ported TB sitting in truck) upd intake
FUEL SYSTEM:Stock
EXHAUST:pacsetter lts, ory magnaflow+bullet
TRANSMISSION & STALL/CLUTCH: stock
REAR GEAR & TIRE SIZE:3:73, 32
SUSPENSION/TRACTION:rear swaybar, rancho rsx schocks, cranked front bars
TRUCK WEIGHT(ASSOCIATED WITH ET):5X00
RWHP/TQ: 245/290
1/4 & 1/8 MILE TIME AND MPH: ? hope to find out soon
Old Dec 2, 2006 | 10:59 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
YEAR, MAKE, MODEL: 2000 Silverado ECSB
ENGINE SIZE: 6.0 LQ4
POWER ADDER SPECIFICS(IF APPLICABLE): N/A (Radix in the Garage )
HEADS: Stock
COMPRESSION RATIO: Stock
CAMSHAFT SPECS: Stock
VALVE TRAIN(PUSHROD LENGTH, ROCKERS ETC.): Stock
INTAKE MANIFOLD & TB: Stock w/ AEM Brute Force "air" intake filter system
FUEL SYSTEM: Stock
EXHAUST: Magnaflow Cat-back (headers in garage )
TRANSMISSION & STALL/CLUTCH: 4L60E Stock w/ Yank TT3000 converter
REAR GEAR & TIRE SIZE: 3.42 with 275/55-17's (28.9" tall)
SUSPENSION/TRACTION: N/A
TRUCK WEIGHT(ASSOCIATED WITH ET): 4880 with me in it (200 lbs of me)
RWHP/TQ: 297/304 (Mustang Dyno)
1/4 & 1/8 MILE TIME AND MPH: 14.40 @ 96
Tuning by F-Body Central
Old Dec 3, 2006 | 02:39 AM
MikeZQ8SS's Avatar
YEAR, MAKE, MODEL: 2006 Chevy Silverado Reg Cab Short Bed 2wd
ENGINE SIZE: 5.3L
POWER ADDER SPECIFICS(IF APPLICABLE): n/a
HEADS: Stock
CAMSHAFT SPECS: 220/220 ?.581 .581? 112lsa
VALVE TRAIN(PUSHROD LENGTH, ROCKERS ETC.): 7.425" pushrods / stock rockers w/ comp springs
INTAKE MANIFOLD & TB: Home made air intake, Stock TB, stock intake manifold
FUEL SYSTEM: all stock there
EXHAUST: Dynatech LT's, High flow cats, off road y-pipe, dynomax muffler dumped
TRANSMISSION & STALL/CLUTCH: All stock for now, 4L60
REAR GEAR & TIRE SIZE: 4.10 gears 265/50/20
SUSPENSION/TRACTION: Hotchkis TVS (2/4 drop) and a detroit tru-trac posi
TRUCK WEIGHT(ASSOCIATED WITH ET): Will find out and update soon
RWHP/TQ: Not sure yet, any guesses give me a PM lol
1/4 & 1/8 MILE TIME AND MPH: been rained out every time... same as above, any guesses send a PM!
Old Dec 3, 2006 | 09:08 AM
02sierraz71_5.3's Avatar
YEAR, MAKE, MODEL:02, gmc, sierra
ENGINE SIZE: LM7
POWER ADDER SPECIFICS(IF APPLICABLE): NA
HEADS: milled .050, bigger intake valve, unshrouding, 5 angle, ferrea 6000 series, 918, stock ports
COMPRESSION RATIO: 10.5:1
CAMSHAFT SPECS: LPE GT2-5 (222/222 ,566/.566, 112/112)
VALVE TRAIN(PUSHROD LENGTH, ROCKERS ETC.): 7.4 tqd to 24ftlbs
INTAKE MANIFOLD & TB: stock
FUEL SYSTEM:stock
EXHAUST: thorley, 2.5 to flowmaster y-pipe, single 3", magnaflow, cutout
TRANSMISSION & STALL/CLUTCH:shift kit, 3kstall
REAR GEAR & TIRE SIZE: 3:73, stock
SUSPENSION/TRACTION:stock
TRUCK WEIGHT(ASSOCIATED WITH ET): 5300
RWHP/TQ:?
1/4 & 1/8 MILE TIME AND MPH: 13.9@ 96/8.8@78
Old Dec 3, 2006 | 09:57 AM
v8
17,16,15,14,13,12,11 Drvr
YEAR, MAKE, MODEL:2001,chevy,silverado regular cab short wheel base.
ENGINE SIZE:5.3
POWER ADDER SPECIFICS(IF APPLICABLE):short belt,tornado
HEADS:Stock
PCM: Nelson 93 tune
COMPRESSION RATIO:Stock
CAMSHAFT SPECS:226 226 585 585 112
VALVE TRAIN(PUSHROD LENGTH, ROCKERS ETC.):7.425,stock rockers,patriot Dual springs
INTAKE MANIFOLD & t/b:stock intake,bbk 80mm,K/N fipk
FUEL SYSTEM:8.1L 31lbs injectors
EXHAUST:dual in,dual out imco muffler,asm long tubes,cutouts at the end of headers
TRANSMISSION & STALL/CLUTCH:century built trans with vig 2500 converter
REAR GEAR & TIRE SIZE:4.10's, 26" e.t streets
TRUCK WEIGHT(ASSOCIATED WITH ET):4195lbs
RWHP/TQ:331/333 without short belt
1/4 & 1/8 MILE TIME AND MPH:12.51/7.89
Old Dec 3, 2006 | 10:10 AM
jakebdb56's Avatar
YEAR, MAKE, MODEL: 2006 Chevy Silverado ECSB
ENGINE SIZE:5.3L LM7
POWER ADDER SPECIFICS(IF APPLICABLE):there should be a pcm part on here on maybe who tuned the truck or if it is tuned. i've only tuned the trans on my truck with HPTuners so far. that's it
HEADS:stock
INTAKE MANIFOLD & TB: K&N 77 series, that's it
FUEL SYSTEM:i run 93 every day
EXHAUST: pacesetter lt's, custom ORY with stock cats
TRANSMISSION & STALL/CLUTCH:the stock 4l60e that's gonna give soon even though it's only 6 months old
REAR GEAR & TIRE SIZE:3.73's stock with the stock g80 locker, stock 265/75-17 (whatever the general ameritrac tires are with 17" wheels)
TRUCK WEIGHT(ASSOCIATED WITH ET):uhhhhh... whatever the stock weight is plus me (250lbs)
RWHP/TQ:dunno yet. haven't gotten to dyno
1/4 & 1/8 MILE TIME AND MPH: 15.1 @ 92mph , no 1/8mile times
Old Dec 3, 2006 | 12:22 PM
Jeff Alexander's Avatar
YEAR, MAKE, MODEL:2001 siverado extended cab short bed
ENGINE SIZE:5.3
POWER ADDER SPECIFICS(IF APPLICABLE):none
ECM:nelson 91 tune
HEADS:stock
CAMSHAFT SPECS:tr220 220/220 551/551 112
VALVE TRAIN(PUSHROD LENGTH, ROCKERS ETC.):7.400, 918, stock rockers
INTAKE MANIFOLD & TB:stock intake and tb, aem bruteforce air intake
FUEL SYSTEM:stock
EXHAUST:pacesetters Lt, ory, 3in 40series dumped
TRANSMISSION & STALL/CLUTCH:stock 4l60e, vette servo, B&Mcooler yank2600
REAR GEAR & TIRE SIZE:3.73, stock 255/70/16
SUSPENSION/TRACTION:lowered 2 in front and 2 in rear, spring clamps, stock g80 posi
TRUCK WEIGHT(ASSOCIATED WITH ET):dont really know 5xxx
RWHP/TQ:???
1/4 & 1/8 MILE TIME AND MPH:2.35 15.21@91.86
Old Dec 3, 2006 | 12:32 PM
ap2002's Avatar
YEAR, MAKE, MODEL:2001 chevy extended cab short bed
ENGINE SIZE: 6.0 (LQ9)
POWER ADDER SPECIFICS(IF APPLICABLE):none (all motor)
ECM:nelson 93 tune
HEADS:stock
CAMSHAFT SPECS:custom grind from comp cam 226/226 .584/.584 112+2
INTAKE MANIFOLD & TB:stock intake and tb, K&N air intake
FUEL SYSTEM:stock
EXHAUST:pacesetters Lt, ory, 3in , hooker aerochamber
TRANSMISSION & STALL/CLUTCH: built 4l60e, 3200 Fuddle
REAR GEAR & TIRE SIZE: 4.10's w/26" e/t's
SUSPENSION/TRACTION: 2/4 drop, detroit trutrac
TRUCK WEIGHT(ASSOCIATED WITH ET): 4760 with me in it..
RWHP/TQ:???
1/4 & 1/8 MILE TIME AND MPH:12.577@105.84 - 7.951@85.61
Old Dec 3, 2006 | 03:42 PM
14 Second Truck Club
YEAR, MAKE, MODEL: 1999 Chevy Ext. Cab Short Bed
ENGINE SIZE: 5.3
HEADS: Stock
CAMSHAFT SPECS: Crane Cam 208/216-.530/.530-113LSA
VALVE TRAIN(PUSHROD LENGTH, ROCKERS ETC.): Hardened 7.400", 2002 LS6 Valve Springs
INTAKE MANIFOLD & TB: Stock/Ported TB
FUEL SYSTEM: Stock
EXHAUST: LaPole Mid-Length headers, Cut-outs, True Duals w/ cats & dual in/out magnaflow w/ internal x-pipe,
TRANSMISSION & STALL/CLUTCH: 4L60E/Billet Servo/Stock Stall
REAR GEAR & TIRE SIZE: 3.90 / Stock 255/70-16
SUSPENSION/TRACTION: Stock
TRUCK WEIGHT(ASSOCIATED WITH ET): 4800
RWHP/TQ: 286/294 (2nd gear with 3.42s)
1/4 & 1/8 MILE TIME AND MPH: 14.56 @ 95mph
