TBSS manifold/TB questions
Old Dec 10, 2008 | 02:30 PM
06sierra5.3's Avatar
Default TBSS manifold/TB questions
i have an 06 5.3 flex fuel. would i still need to modify the fuel rail or injectors, or can i just swap them over? i saw in another recent thread that someone used a FF rail
is there an adapter that i can put on to use the TBSS manifold, but keep the stock size TB? i know it seems like it would be a waste, but im wanting to wrench on something, and i wouldnt mind spending the time (not the money) to see if i gain anything at all from it. i already have the manifold i bought a while back.
Old Dec 10, 2008 | 04:16 PM
skyhighsami's Avatar
no title here
I know the truck TB is a 3 bolt flange and the TBSS is a 4 bolt flange. The adaptor would be truely unique and would have to cut the bolts I would imagine since the adaptor would bolt to the intake and the TB bolt to the adaptor itself. Without efans I would think clearence between the engine driven fan shroud and fan would be tough. Just my thoughts. I bought a complete TBSS intake, Dr. X harness, and the pigtails to splice the injectors to my truck wiring. Of course I would have to have the tune corrected for the intake added volume and different fuel injectors.
Old Dec 10, 2008 | 08:57 PM
i initially wanted to do the 90mm setup, but after talking to a few guys who know their stuff, they suggested i stick with the smaller TB for velocity over volume. the 90mm would be well suited for the 6.0 or larger. this makes sense to me.
i thought someone mentioned there was an adapter somewhere
has anyone noticed gains from a 90mm on a 5.3?
Old Dec 10, 2008 | 09:07 PM
the rails are the same on the flex fuels and tbss mine fit perfect !
Old Dec 10, 2008 | 09:18 PM
awesome, thank you. did you have to do any mods?
Old Dec 10, 2008 | 09:57 PM
andrew383's Avatar
traveling mod
fast used to make a 78mm tb for the fast intake,but i dont see it on there site.just stick with the tbss tb
blownss27
Aug 14, 2020 08:27 AM
Pontiac Derek
Sep 19, 2015 01:49 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alco
Sep 4, 2015 04:08 PM
iVorTec
Sep 2, 2015 04:27 PM
