tbss intake vs nnbs intake on a 05 lq4
Old Aug 19, 2012 | 07:02 PM
teamblackandred's Avatar
Default tbss intake vs nnbs intake on a 05 lq4
im getting mixed info on the two intakes. do they flow about the same just one has a bigger tb? i was thinking of doing a tbss intake setup but i hear a nnbs will give me the same gains on my 05 2500 crew cab. any info would be great
Old Aug 19, 2012 | 07:06 PM
Chevy_King1500's Avatar
They are the same, iirc they both come stock with the 87mm throttle body and you will need an X-link for the throttle control
Old Aug 19, 2012 | 07:23 PM
thanks man
Old Aug 19, 2012 | 07:43 PM
Mangled03gmc's Avatar
Baltimore Whore
Yup same intake afaik.
Old Aug 19, 2012 | 10:46 PM
ShredSled's Avatar
not quite the same.... nnbs has a few differences as far as some of the ports go, like pcv on top for example...
flow would be same I'd imagine.
Old Aug 21, 2012 | 09:41 PM
chevybuilder383's Avatar
What are you doing for MAF, I'm doing this same swap, along with ported 243 heads and changing my hot cam for something bigger, I don't see the point in doing this swap and still breathing through a small MAF will the bigger one plug in do you need an adapter
Old Aug 22, 2012 | 11:52 AM
ShredSled's Avatar
I'm just using the stock maf... I honestly don't see it as being that restrictive at this point, but you could go to a lingenfelter 100mm if you were really concerned about it and your pockets were a bit deeper.
noproblems209
Aug 10, 2015 06:57 PM
Ammadien
Jul 22, 2015 08:50 PM
fat tony157
Jul 16, 2015 12:35 PM
06 4.8
Jul 14, 2015 08:09 AM
blackdc3
Jul 7, 2015 07:52 PM
