TBSS intake swap and need harness info
Going to be doing some changes over the winter and have purchased an 09 TBSS intake, fuel rail, and E85 injectors all together.
I have an LQ4 with the Multec II injectors, I can not find the style of injectors that are on the 09s...and I need to get an adaptor harness or cut and splice it.
You need the evap solinoid and lines too
cut n splice the injector connectors will probly be easier
I wanna say adapters are about $90 i looked into this
Or you can put your stock injectors in the TBSS fuel rails for plug n play operation
I will be doing this swap soon as i order the x link to run the throttle body
FYI just saw some adapters in the classifieds for 80 shipped
I am going to run the E85 injectors, I need the bigger ones, over the LQ4 ones.
I just need to know am I looking for EV6 or EV1, or what....
and have the EVAP stuff too...but may not use it....
This is a swap in a 71 chevy truck
the nnbs FF injectors are EV6/UScar connectors, not sure if the reg nnbs injectors are the same or not.. i got my adapters from fiveomotorsport, there not as cheap as splicing but i didnt want to go that route..
And i would just tune out the evap if this is going in a 71truck, too much hassle..
Nimoryan
Jul 5, 2015 03:50 PM
