In tank Walbro in a 2002 fuel sender-pics
Old Aug 7, 2005 | 07:45 PM
ranwalk's Avatar
I put a piece of shrink tube in a cup of gas. It's been there over 24hours and so far its fine. I'll just leave it there and if it starts to fall apart or somthing I'll know i gotta drop the tank and do somthing else.
Old Aug 19, 2005 | 09:58 AM
BigTex's Avatar
Put that heat shrink in a small sealed jar of gas and put it on a shelf in your garage. Every so often, shake it around a little and take a look at it. You may find that it starts to decay over time.
I also think it should be fine on a low tank of gas, with the exception of hard accelleration. Of course, the last thing you want is to be full throttle under boost and lose fuel pressure.
Idea: Buy a fuel pressure safety switch that would normally be used for a nitrous install. Install it so that on low fuel pressure, it trips a relay that activates an LED light or a buzzer in the cab. Better yet, it could open an electric boost bypass to save your butt.
Old Jan 17, 2006 | 04:01 PM
BigKID's Avatar
Randy, this is the same pump from THIS THREAD? F20000619?
Have you run into any problems since the install?
Old Jan 17, 2006 | 04:05 PM
ranwalk's Avatar
Yep, that is the same pump I installed. 4000 miles on it and so far no problems. I have even driven it with as little as an 1/8 tank of gas, but didnt dare go WOT with the fuel that low.
Old Jan 17, 2006 | 04:26 PM
BigKID's Avatar
Great, thanks. I sent APE a message last thrus and they have yet to get back with me.
Old Jan 17, 2006 | 09:31 PM
wow, i didn't modify my sending unit at all. just put the filter on and dropped it in there. is that gonna be a problem?
Old Aug 1, 2006 | 08:25 AM
Holty's Avatar
Notorious BIG
bump, hows this coming along and why does this not count for the '03 guys?
Old Aug 1, 2006 | 11:47 AM
Lord Aries's Avatar
would it be any dif on a 2003??? I have a Walbro 255 to install but, am not sure i want to do it my self...
Old Aug 1, 2006 | 03:34 PM
ranwalk's Avatar
I just recently removed it and installed dual intank pumps. Never had any problems with it and all looked great when removed.
It may work with a 2003 and up, but not sure.
Old Aug 1, 2006 | 03:54 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Pics of the dual setup? The "bucket" that holds the actual pump is different on the 03s and up. I forget which walbro it is but there is one that is a direct replacement and no modifying is needed.
