TACH WIRE????
Old Aug 7, 2003 | 11:52 PM
Banned
Default TACH WIRE????
which wire in the little connector going into the gauge cluster is the one for the tachometer? i've heard white, and i've heard grey, so which is it? or is it either...you guys that have tachs let me know what you did. i want the stock tach to not work and the new one to be the primary since it will be more accurate.
Old Aug 8, 2003 | 12:03 AM
RED2K's Avatar
Default Re: TACH WIRE????
Wait till i get back down and you can copy my setup. Mine is on a white wire
Old Aug 8, 2003 | 12:08 AM
Banned
yeah...but i don't want to run it from that wire...i want to run it from the wire on the harness plugging into the cluster. maybe it's the same wire.
Old Aug 8, 2003 | 04:12 PM
Banned
is there anywhere on the web with a wiring diagrham for our trucks????
Old Aug 9, 2003 | 07:13 PM
GREGGO's Avatar
Matt, like I said in the other thread, the white wire on the #10 pin on the PCM is the tach output wire. It is the same wire on the cluster. There should only be one SOLID white wire up there.
Old Aug 9, 2003 | 07:33 PM
Banned
so i can just clip the wire going into the cluster and hook it to the one on the tach and i'm in business?
Old Aug 10, 2003 | 08:20 AM
one03sierra's Avatar
Formerly one92rs
it may be different now but on my 99 i had to hook up one tach or the other.
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Wrecker 426
Sep 30, 2015 09:39 PM
