Tach in NBS
Old Jul 16, 2005 | 09:18 AM
chevythunder06's Avatar
In the 12's??????
Default Tach in NBS
I was just curious as to how to wire a tach (autometer) into a NBS truck, being that there isnt a distributor to wire into. Is there something that Autometer sells to help us wire a tach in to our trucks?
Thanks,
Jesse
Old Jul 16, 2005 | 09:26 AM
BLUE'03's Avatar
Had a monster tach in my '03,Go to autometers web site.In the tech section there are instuctions.Really easy,I have them written down but i'm at work or i would send them to you.If i remember the main tach wire goes to the ecm.Simple.
Old Jul 16, 2005 | 09:46 AM
In the 12's??????
White wire to PCM, pin #10. not to bad. If I dont have on my 04 I have to get adaptor harness. Still, no problem. Thanks for the help.
A lot easier than I thought.
Jesse
Old Jul 16, 2005 | 09:49 AM
You'll need to set the tach at the 4 cylinder setting for it to read correctly.
Old Jul 16, 2005 | 10:35 AM
bluecajun5.3's Avatar
11 Second Truck Club
you can tap into the white wire behind the gauge cluster for the tach, run your ignition wire to an ignition fuse on driver side of dash, run your lighting wire to the dimmer switch (find the wire with a test light and move the dim control) to find it, and last a good ground.
LSXstef
Dec 22, 2015 08:31 PM
Chewy07
Nov 14, 2015 09:46 PM
zblee
Sep 17, 2015 07:58 AM
Gmc_sierra
Sep 13, 2015 10:02 PM
silver-mod-o
Sep 7, 2015 10:22 PM
