swapping throttle bodies...
Old Jun 27, 2007 | 12:08 PM
silveradokidd_4518's Avatar
Default swapping throttle bodies...
i have been looking around for a V8 to swap out with my V6 and i keep finding a lot of 03-06 models engines with DBW...my question is if i was to buy an 03-06 engine with DBW throttle body and could i swap out the throttle body from an engine that uses a cable driven throttle body??
-John
Old Jun 27, 2007 | 01:00 PM
agreif's Avatar
yes, you can.
Old Jul 11, 2007 | 12:51 PM
nonnieselman's Avatar
how? .
Old Jul 11, 2007 | 02:12 PM
agreif's Avatar
throttle body swaps right over. only thinks that I had to change was
A) remove the tube nipple on the intake for the top hose in this picture. My 07 intake had that nipple on the intake, not on the TB like the one shown in the picture.
B) get two M6 threaded inserts from lowes to insert into the top of the intake for the throttle cable mounting bracket (back of the intake in the 2nd picture) (they were a rubber grommet insert that I removed the rubber from and JB welded it into the bosses that are in the intake,
C) you'll may have to swap drivers' side fuel rail depending on what your current fueling setup is.
Really not that bad.
http://bertok.us/agreif/engine/17_upper_rad_hose.JPG
http://bertok.us/agreif/engine/08_engine_doc2.JPG
Old Jul 11, 2007 | 02:33 PM
What about wiring up the TPS and IAC?? and gettin it to work with a 04 PCM?
I have a 2000 PCM at home if it would work...? but copy the tables from the 6.0 and 80e tables over to it??
Or just find the BCM, Gas Pedal and that kindof stuff..??
Old Jul 11, 2007 | 07:53 PM
agreif's Avatar
from a V6 ot a V8 not sure. I know from my 4.8 to 6.0 the iac and TPS were the same plugs. Here is the writeup on what I did.
http://bertok.us/agreif/engine/EngineSwap.htm
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Oobray
Jun 13, 2022 03:38 AM
OHsixLS3
Dec 27, 2016 09:30 AM
05GMC4.8
Aug 7, 2015 09:55 PM
GreyChevy
Jul 7, 2015 08:57 PM
