Swapping heads from an LS1 to a 5.3 and need some help!!!
Old Jan 29, 2009 | 07:41 AM
Default Swapping heads from an LS1 to a 5.3 and need some help!!!
I have been looking in at getting some 241 or 853 heads off of an LS1 and putting them on my truck. I know that the only difference is the intake valve size, but instead of spending $1100-1400 I thought about going this route. I have 706 heads and if my calculations are correct then I should just have to mill the heads down (.039) and the compression should be back up to about 9.5:1. My only concern is milling them that much. Would this even be possible. Does anyone have any opinions or know anyone that has done this or know a machine shop with some knowledge. Mine local just looked at me and said, "Yeah we'll get it done, you should have any problems, We've milled way more that that before. But we can't be certain."
Old Jan 29, 2009 | 10:56 AM
I have also been looking at the 243 heads. Does anyone know specifically what these were on. I noticed that they had a little more compression than the 241's and a little lets combustion chamber cc's. Would these be easier or more difficult to proceed with on my application? Also, do the LS1's use flat top pistons. My only concern is the valve to piston clearance.
ANYONE???
Old Jan 29, 2009 | 11:24 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
243's are a way better breathing head (from what I've read) chamber size is 64cc so they'd have to be milled down, as you already know. 243/799 head castings were found on LS6/LS2 and some 5.3L truck engines (L33 for one).
Old Jan 29, 2009 | 11:59 AM
midnight_bowtie's Avatar
PMed you a link.
Old Jan 29, 2009 | 12:13 PM
Thanks guys. Did the LS1's come with flat top pistons? And if I I mill it and stick it on, it should be about stock compression right.
Old Jan 29, 2009 | 12:35 PM
Also, I still can not find anything on the valve to piston clearance. Can anyone help me with this part. I did find a machine shop here in town that will mill them for me. It's just finding out about the clearance. I really don't want to have to order them and find out that it will not work. Or have to order some new pistons.
Old Jan 29, 2009 | 12:38 PM
Wife wouldn't like the pistons too much. Although, it would be really nice though. Because that can lead to other things.
Old Jan 29, 2009 | 01:27 PM
Also, in the link above, what is the difference in the perimeter bolt and the center bolt?
Old Jan 30, 2009 | 05:46 PM
GM started putting the 243 "LS2" castings on the Gen IV 5.3s, I wonder how they dealt with compression. Pistons, or milled heads?
Old Jan 30, 2009 | 06:08 PM
Truckshop's Avatar
i had 243's milled .040 with a tr220 cam in my truck before i swapped in the 6.0. if ya want some advise from the been there done that then instead of saving for some heads just find a 6.0 and a cam and move on.
