Swappin a LS2/3 onto a 2010 tahoe
Old Dec 29, 2010 | 12:56 AM
Naf's Avatar
Naf
Default Swappin a LS2/3 onto a 2010 tahoe
Ok, i did a nice engine build where i got a ls2 lower unit and installed ported LS3 heads and an escalade intake installed...I would like a little more air to go inside the engine, but i feel my stock tb is holding me back...Its a six pin just like the LS2/3 but neither the LS2 nor the LS3 tb work on my tahoe...
No movement, just a reduce engine code.
Does anyone know what wires i have to change to get the bigger tbs to work on my truck?
The torque rush will not work for its for the old 8 pin to the new 6 pin...I am a 6 pin that probably needs a few wires swapped around...
Old Dec 29, 2010 | 08:35 AM
Tootall's Avatar
Your post is a little confusing to read. So you have a 2010 Tahoe, with a built LS2 ?
Did you swap the reluctor wheel on the crank? . . . any more info on your setup?
If you already have a 2010, it should already have the 4 bolt TB on it with the brass TB blade
Old Dec 30, 2010 | 01:58 AM
Naf's Avatar
Naf
Sorry, allow me to clarify...
The engine is a LS2 with the correct Reluctor wheel on the crank and i evenhave the Compcam Phaser, 4x cam sensor, and 4 bolt TB with brass blade...
The engine runs fine, but i would like to put the larger TB on it. I tried the LS2 with the silver blade and it didnt work. I even have the LS3 TB with the brass blade and that one is also not working, giving me codes where the low and high are not correct.
I noticed the rear opennins on the LS3 and LS2 TB are larger than the stock truck ones which will allow my engine to pull harder up top...
Infernohoe
48
Oct 2, 2015 10:25 PM
mitchellmade
Sep 27, 2015 08:27 PM
lxcoupe
Sep 23, 2015 12:11 AM
project-pegasus
Sep 18, 2015 08:22 PM
chvy=power
Sep 8, 2015 11:06 AM
