Swap Questions? 5.3 to 6.0h
Old Aug 14, 2007 | 04:56 PM
Toaders's Avatar
Default Swap Questions? 5.3 to 6.0
OK Guys,
I have finally pulled the 5.3 from my truck. After 2 weeks of soaking the bolts n the collectors and many attempts trying to disconnect the motor from the trans it's out. I called the guy at the salvage yard and my 2004 6.0 with 5,500 miles is waiting for me. I will be picking it up tomorrow around 1PM and my goal is to have it in by the weekend. I also want to detail the engine compartment while the motor is out. My question is what problem am I going to run into. So far I have the following.
1. Oil sender unit might have different connectors.
Fix = using the one from the 5.3
2. 04's have returnless fuel system
Fix = using the intake off the 5.3
3. I was told there will be a crank spacer that will need to be removed so the engine can mate to the 4L60e? Does anyone know about this?
4. The waterpump neck might be different I have also heard? Does anyone know about this?
And anything else you guys can think of is greatly appreciated.
Old Aug 14, 2007 | 05:35 PM
thunder550's Avatar
High on diesel fumes
Fix = using the one from the 5.3 Yep
Fix = using the intake off the 5.3 Yep
3. I was told there will be a crank spacer that will need to be removed so the engine can mate to the 4L60e? Does anyone know about this? - Just use the flexplate off your old engine
4. The waterpump neck might be different I have also heard? Does anyone know about this? The necks should be the same. The difference is in the thermostat. The older model years use a 1 piece thermostat and housing, where the newer ones use a separate thermostat and housing. Personally, I would make the switch to the newer water pump because it should have lower miles than yours, and if you ever need to replace the t-stat, it is cheaper, but that decision is up to you. Both pumps will work fine
Old Aug 14, 2007 | 05:47 PM
Toaders's Avatar
Thanks man Yes I want to use the one with less miles I was hoping it would work. I can't wait to drive my truck again!
creekrat
Aug 2, 2015 01:27 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
06 4.8
Jul 15, 2015 07:17 PM
grantpo
Jul 15, 2015 12:21 PM
