suspensions
Old Apr 2, 2003 | 10:18 PM
02 black 5.3's Avatar
Default suspensions
has anyone combined suspensions like use the hotchkis coils plus the djm control arms and the hotchkis leafs plus 2 inch hangers in the rear to get a total of 4/6 drop that handels well.
Old Apr 2, 2003 | 11:49 PM
redaddiction's Avatar
Default Re: suspensions
i would like to know this also but i was going to use drop spindles instead cuz i want to keep the handling of my hotchkis setup
marc
Old Apr 3, 2003 | 12:28 AM
454SuperSport's Avatar
there is a guy over at fullsizechevys.com that uses the hotchkis kit along with djm control arms and shackles for a very nice handling 4/6 drop. i am using the hotchkis kit and a set of djm shackles to make it sit perfectly level at all 4 corners. redaddiction, from all the info i've heard the spindles are a big no-no on the silverados.
<small>[ April 03, 2003, 12:31 AM: Message edited by: 454SuperSport ]</small>
Old Apr 3, 2003 | 05:26 AM
Yeah,454 is right I had a set of belltech spindles on mine and they sucked. They really cut down on your turning radius. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> I took mine back off after about a month and put it back stock with a shackle. Would like to try the hotchkis kit someday.
Old Apr 3, 2003 | 07:11 PM
thanks, I think that I am going to start with the hotchkis and then go from there depending on the way it does.
P.S has anyone gotten a sway bar off of a suburban or H2 and tried to fit them on the trucks. i think it would be alot cheaper then the hotchkis
Old Apr 3, 2003 | 07:47 PM
not sure on the sway bars but i will tell you that i love my hotchkis kit. it eliminated the wheel hop problem i was having and i love the way it rides. much better feel of the road than stock. you'll be very happy with it.
Old Apr 4, 2003 | 12:14 AM
yeah i love my hotchiks setup also but i wish it was a little bit lower to fill up the gap between my tires and fender but i guess i could lower it some more i use to have a 4/6 but you can't go very fast with that
marc
pewter00
11
Oct 20, 2023 05:40 AM
97_ek
Sep 23, 2015 09:16 PM
whitelazer
Sep 22, 2015 09:38 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
