Supercharger ???'s
#22
The Lightning uses a M112 with a top mounted inlet port and a pressed on pulley.The Radix uses a M112 with improved intake porting and a keyed pulley.The combination of an upgraded supercharger and better breathing heads make the Radix LS1 combination stronger than the Ford at lower boost levels.
#23
#26
Originally Posted by Ripped427
I've seen many, many posts calling the Radix a Roots and the others Twin Screws. I'm just wondering how much difference there actually is between??
Being the Rotors on the Radix are twisted I wonder how much difference there is between the rotor profile?
It be nice to see some pictures to compare them and some profile maps on the lobes.. Anyone know anything?????
#27
So basically, from what I've read, the Kenne Bell is the more effecient, and basically the better Supercharger. Their customer service may not be the best, but the supercharger is better. A piston upgrade may be needed for optimum performance, but that goes for most Supercharger's right? And how about the intercooled twin-screw idea? Is there such thing as an intercooled twin-screw supercharger???
#28
Bang for the buck, the Radix is the way to go IMO. Piston upgrade? Why? I am running 10 psi on a 68k motor daily driven! If you want OEM reliability and easy installation where there are no questions, and EVERYTHING is there then the MagnaCharger Radix should be your only choice.
#30
btw.. my $.02.. from all my research, I will be going with a radix once I save the change for my sc purchace.
