Supercharger guys..
Old Oct 31, 2004 | 08:52 PM
Originally Posted by XFACTOR
Is your procharger noisy or what does it sound like?? i do plan on getting a stall but want to get the expensive mod done and then get the other stuff afterwards.
if you want to hear a procharger clip, go here and listen to what my truck used to sound like, the numbers were before i tuned it in
start listening from 40 sec all the way to 1:10
http://www.1320video.com/videos.php
go to the supertune dyno day video
Old Oct 31, 2004 | 09:14 PM
Black Blown 02's Avatar
It sounds kinda like a bad bearing at idle. Like grinding. Driving around town, you hear a loud air rushing sound from the bypass when not in boost. I really can't hear anything at WOT.
Old Oct 31, 2004 | 09:20 PM
greentahoe's Avatar
My vortech sounds pretty cool at idle and part throttle. There are 2 problems with the kit so far. Im trying to figure out how to route piping for a FMIC and the MAF is preblower. Post blower seems to be the better way to go and that way you can vent to atmosphere instead of having to reroute the compressed air back into the system. My plan is pretty much to see how far everything will go when setup properly (5.3. tranny, and compressor) and upgrade as needed. I really want to see how well this V2 flows on the 5.3 and 6.0 and then I will upgrade to a T trim or maybe even a turbo.
Old Oct 31, 2004 | 11:27 PM
the rattling sound is the oil slinger that sound goes away even with the slightest touch of the gas. you wouldnt believe how much louder the exhaust is with the procharger even with stock exhaust. my cutout plate was open during that run. from the inside of the car you can hear it whining. when it blows off it sonds really cool too.
Old Nov 1, 2004 | 12:43 AM
James B.'s Avatar
There is some strange information in this thread, maybe I can help.
Roots superchargers (Magnason/Radix/Eaton) are positive displacement blowers. They move a fixed volume of air from one side to the other in the cavities created between the lobes and the housing. Boost is steady from off-idle through the entire RPM range. This unit is not a compressor - air simply piles up on the discharge side.
Twin Screw superchargers (Whipple/KenneBell/Lysholm) are true compressors. The two rotors, male and female, have a different number of lobes - usually 5 to 3. The rotational RPM difference between the two rotors corresponds to this also. Twin Screw compressors move a fixed volume of air axially, usually rear to front, unlike a roots which moves air perpedicularly. The cavity of air trapped between the rotors and the housing gets gradually compressed as it is moved through the unit. Twin Screw superchargers also maintain steady boost through the entire RPM range.
The throttle bodies on a roots or twin-screw system are on the intake side of the supercharger. At idle rotors are under the same vacuum the intake manifold is. There is a bypass valve. This valve is normally open to allow bypass at throttle positions where the intake is under vacuum. As throttle increases and vacuum drop the bypass closes and allows boost to build on the discharge side of the supercharger.
Centrifugal superchargers (Vortech/ATI Procharger/Powerdyne/Paxton) are variable displacement blowers. Boost from these increases exponentially as RPM increases. The load on the belt needed to drive this boost also increases at the same rate. Centrifugals need to be sized to provide maximum tollerable boost right before the shift point without resorting to bypass to control pressure. The throttlebody in a centrifugal system is usually left at the stock location at the entrance to the intake manifold. The discharge side of the supercharger is either plumbed directly to it or first through an aftercooler and then on to it. The purpose of the bypass valve is to prevent overboost. In some systems the bypass is vented to the engine compartment and sometimes it is plumbed back to the inlet side of the supercharger. The placement of the MAF sensor in the induction path determines the type of bypass that is acceptable.
A twin-screw or roots supercharger will work well with a relatively low-stalling torque converter. A centrifugal system will come alive with a relatively high-stalling converter.
Roots and twin-screw superchargers ARE harder on the drivetrain than centrifugals because boost is instantaneous and can come on very abruptly, partiularly during a downshift.
Old Nov 1, 2004 | 06:02 AM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Sounds to me like JamesB knows his ****!
Old Nov 1, 2004 | 08:40 PM
James B.'s Avatar
Not really.
Maybe more than some but not as much as others.
Old Nov 1, 2004 | 08:46 PM
Think this has made my mind a little clearer now. But still sounds like either one would be a good decision just depends on when you want boost.I want instant boost so if im seeing this right i need the radix right?
Old Nov 1, 2004 | 08:49 PM
how about a powerdyne there only like 2500 dollars are they any good?
Old Nov 1, 2004 | 09:02 PM
Mangled03gmc's Avatar
Baltimore Whore
alot of people say that they are junk and they have probs wit the compressor/bearing wearing out.others will say they are nice.i have no expereance wit them but you get what you pay for..02
