supercharged 6.0 how much power?
Old Mar 29, 2012 | 08:44 PM
  #31
Link2603's Avatar
here are some pics its not done but getting closer everyday
Attached Thumbnails supercharged 6.0 how much power?-photo-6-.jpg   supercharged 6.0 how much power?-photo-8-.jpg   supercharged 6.0 how much power?-photo-9-.jpg   supercharged 6.0 how much power?-photo-10-.jpg
Old Mar 30, 2012 | 12:28 AM
  #32
kalebm22's Avatar
Restricted User
that intercooler setup looks awsome! i measured my pulley and from outside of rib to outside of rib is 3.75" is there a place to get a 3 3/8 pulleey? i could definately use more boost later on im sure. i think my shift points are goin to be around 6500 and i would like to make 10lbs of boost on this setup if even possible. i really need to know the size on cam bearings if anyone knows it too. thanks!
i also installed the aero 340 pump and it was supersimple to do. im very pleased with the pump, i may go slap the truck on the dyno once i get the 6.0 done then slap the new engine in and see what power difference there actually is.
Old Mar 30, 2012 | 07:33 AM
  #33
Link2603's Avatar
I bought my from whipple. They told me they only had two pulleys in stock a 3 3/8 pulley and a 2 5/8 pulley. The 2 5/8 pulley is still a 6 rib so I think belt slippage would be an issue I think. They told me I would See 14 to 15lbs with the 2 5/8 and 9 lbs with the 3 3/8 pulley.
Old Mar 30, 2012 | 08:57 AM
  #34
kalebm22's Avatar
Restricted User
Wow!!! That's incredible, how much is a pulley?
Old Mar 30, 2012 | 09:25 AM
  #35
Link2603's Avatar
89.99$
Old Mar 30, 2012 | 10:48 AM
  #36
kalebm22's Avatar
Restricted User
That's not bad at all, thanks for filling me in on that! Is it 9lbs of boost on a 6.0 or 5.3? Also how much does head flow and cubic inchs effect boost psi? Is there a pretty common theory for boost drop? And if a person was to make a bracket for a second tensioner is it possible to make the 2 5/8 pulley work?
Old Mar 30, 2012 | 12:36 PM
  #37
Link2603's Avatar
I told them I had a 6.0L so I'm assuming the number they gave me was for that. The theory is a pound for every 1/8 in you go Down starting with the 4 in which is supposed to be 4lbs. Which means a 2 5/8 is supposed to be 16lbs but they told me less so I don't know if there already figuring belt slippage. Better flowing heads will drop boost pressure. Boost pressure is a measurement of resistance so the Better The engine flows the lower the number, which is actually a good thing so don't be worried about seeing a lower number then expected. I wouldn't put another tensioner on until you see what it does. Also the belt for a two pulley setup is 69 1/2 inches which I found to be tough as hell to get on lol
Old Mar 30, 2012 | 12:46 PM
  #38
nonnieselman's Avatar
cam makes a big difference in the boost readings.
Old Mar 30, 2012 | 07:40 PM
  #39
kalebm22's Avatar
Restricted User
i really appreciate you guys helping me out with all this, im new to the whipple seen and i work 70+ hours a week so i have almost no time to work on my truck or my car so it makes it even harder to search for answers. so i cant thank you enough for your help
Old Mar 31, 2012 | 12:52 AM
  #40
Link2603's Avatar
Also since I'm sure you be ditching the whippletronics you will need to research how bypass your whipple so you can see more then four pounds.
