supercharged 6.0 how much power?
i am building a 2007 6.0 lq4 with floating rods. it will have lightly worked 317heads. cumbustion chambers and exhaust will be polished. so will the piston tops.
cam lloyd elliott 224/235 .610 .614 115lsa
9.5 to 1 compression
aproximately 8-9lbs of boost from a whipple side mount supercharger. no intercooler as of now. im allso running a ported throttle body and a filter directly off of it.
electric fans
1 and 3/4 longtube headers
straight thru muffler no cats
3200 circle d converter
33x12.50 tires
3.73 gears
4500lbs
im also looking for some advice on a fuel pump. please help!
what are some rear wheel hp guesses?
electric fans
33x12.50 tires
3.73 gears
4500lbs
you need to do some trans work as well if you want it to live
not having an intercooler is going to hurt, especially on the top end when temps skyrocket, the tires are also not going to help being oversized offroad tires
realist hp would be around 500-550hp to the ground
aeromotive 340 pump should be sufficient
im not worried about the trans, ive got a really good transmission guy that builds stout transmissions for me for a little bit of nothing.
but since mine is a 4x4 i dont really want to change gears. the front diferential scares the poop out of me lol
i do already have the blower on my current 5.3. makes 10-11psi on it
i will be adding an intercooler later on but i just need to get the motor in and lined out befor i go into that.
does the areamotive pump go inline orr is it an intake pump? is it a direct swap or is there some fab work involved? maybe a write up i should look into?
i would be thrilled with 500rwhp tho. i would think that would throw me into the 12s somewhere
