supercharged 6.0 how much power?
Old Mar 28, 2012 | 10:42 PM
  #21
kalebm22's Avatar
Restricted User
Also can I use my 2002 5.3 balancer and flywheel on the 6.0 engine? My truck has the 4l60e. And is there a stronger flywheel available? I bent my stock flywheel on a 4wheel launch
Old Mar 28, 2012 | 10:47 PM
  #22
Atomic's Avatar
I have a gauge for that
Yes on the balancer, and no the flywheel; you dont have one. If you mean the flexplate, then yes, it will swap over, assuming the 6.0 has aluminum heads and isnt one of the 99-00 6.0s with the iron heads.
There are stronger ones out there from tci and circled I can name off hand.
Old Mar 28, 2012 | 11:07 PM
  #23
kalebm22's Avatar
Restricted User
I've never heard that called a flexplate, I thought flexplate was in a clutch. But do you have a part number on the tci? Or do I just look one up for a 5.3?
Old Mar 28, 2012 | 11:25 PM
  #24
kalebm22's Avatar
Restricted User
Also what cam bearings do I need for the 2007 6.0 I read somewhere there was 2 different sizes for ls engines.
Old Mar 29, 2012 | 12:48 PM
  #25
Bama2door's Avatar
Originally Posted by Link2603
What size pulley are you going to run? Also you can put a A to A intercooler on fairly easy. I actually just got done putting to exact same blower on and the intercooler helped alot. I'm running a 3 3/8 pulley.
Any pictures?
Old Mar 29, 2012 | 01:52 PM
  #26
2 tone 02's Avatar
You got them mixed up bud!
Old Mar 29, 2012 | 02:38 PM
  #27
oakley6575's Avatar
Clutch mounts to the flywheel. Torque converter mounts to a flexplate. They are very different.
Old Mar 29, 2012 | 02:47 PM
  #28
kalebm22's Avatar
Restricted User
I know the difference in the two lol. But in many repair manuals it refers to it as the flywheel even in autos.
Old Mar 29, 2012 | 03:03 PM
  #29
oakley6575's Avatar
Ignorant writers
Old Mar 29, 2012 | 05:02 PM
  #30
Link2603's Avatar
Gettings 550 is possible but I haven't seen anybody make that power with the older whipple's. But not many people are doing what you are to optimize the power of it either. I will post up picks later on my whipple and the intercooler setup I did. Also I went with dual walbro 255 intank pumps and five o Motorsports 60lbs injectors, and my cam is 215/227 .603/.613 116lsa
