supercharged 6.0 how much power?
Old Mar 23, 2012 | 06:29 AM
gagliano7's Avatar
How much power did you make with 5.3 supercharged?
Old Mar 23, 2012 | 07:27 AM
kalebm22's Avatar
Restricted User
It hadn't been on a dyno, I have a metal to metal sound like a rod knocking. So I'm waiting until I have another engine ready for it before I take it to the track
Old Mar 23, 2012 | 09:06 AM
Bama2door's Avatar
You want the 340 with the center inlet (pn 11140). When I installed mine I had to cut the line going from stock pump to fuel filter. The new fuel line provided is too short to run so I had to order some gates submergable fuel line (this is important) and put hose clamps on the ends. Then you need to cut the 2 plug wiring harness running from stock pump to top of bucket and solder the new AM harness in. The AM pump comes with a rubber boot, I slide this on the top of the pump and then pushed the pump down in the bucket an made sure it was snug. Then put new sock on bottom of pump and then put the whole unit in the bottom part of the bucket and you're done.
** just make sure you use submergable fuel line! I made the mistake of not doing this the first time and the regular line had swollen up and popped off the fuel filter and I had to drop the tank again...don't make the mistake I did haha
Btw this is for a returnless fuel system, not sure what you have since your truck is an '02 with a '07 motor...
Old Mar 23, 2012 | 09:10 AM
ak2007r6's Avatar
Run it till she finally blows huh?
Old Mar 24, 2012 | 07:25 PM
kalebm22's Avatar
Restricted User
Haha yes sir! I never seem to getting an engine built for something befor it comes apart:/
Old Mar 25, 2012 | 06:39 PM
kalebm22's Avatar
Restricted User
Do I need the gates 3/8" submersible fuel line or a different size?
Old Mar 25, 2012 | 07:18 PM
Atomic's Avatar
I have a gauge for that
You need 5/16"
Old Mar 26, 2012 | 05:49 PM
kalebm22's Avatar
Restricted User
Thank you! I'm trying to get my hands on a set of 317s for a good price. No luck yet
Old Mar 28, 2012 | 08:50 PM
Link2603's Avatar
What size pulley are you going to run? Also you can put a A to A intercooler on fairly easy. I actually just got done putting to exact same blower on and the intercooler helped alot. I'm running a 3 3/8 pulley.
Old Mar 28, 2012 | 10:40 PM
kalebm22's Avatar
Restricted User
Send me a part number or the site where you got the intercooler cause I am definately interested. I will measure my pully sizeabd let you know. It is a 10lb pulley for the 5.3s is all I know. I maintain 10lbs and peak at 11lbs. In sure the 6.0 will be lower tho. Do you think am intercooler is woould get me to the 550rwhp mark?
