This sucks, need some advice!
Old Oct 3, 2004 | 03:43 PM
abbo7's Avatar
Default This sucks, need some advice!
This sucks! I was taking off my ASP pulley with one of those 3-prong pullers with the 3 smaller bolts that screw into the front of the ASP pulley and when I was spinning the bolts into the front of the pulley one broke off in there. This is going to be a pain to get out, I guess I will have to get underneath the truck and tap into the broken bolt with one of those tools that drills into broken bolts and backs them out. Unless there is another puller that will work. Anyone have any suggestions?
Old Oct 3, 2004 | 08:56 PM
BigTex's Avatar
Ooooh.... Not sure. Gonna be a pain unless another puller will work. I'd research other pullers as my first option.
Old Oct 3, 2004 | 09:06 PM
v8
17,16,15,14,13,12,11 Drvr
no problem i had the same thing happen to me , get a right angle drill and drill a 1/8" hole and get a easy out from any auto part store it worked for mine. as long as you didnt over tighten the bolt then your fine.
P.S. if you remove the fan and shroud you should be able to get a 3/8 drill into the area
Old Oct 3, 2004 | 11:14 PM
abbo7's Avatar
Thanks guys, I guess I will try the easy out first, if that doesnt work (which I hope will) I will have to research other pullers.
bearden86
26
Nov 15, 2015 03:58 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
trxmxzx
Sep 29, 2015 07:42 AM
Chevy305
Sep 28, 2015 09:21 PM
Cha_Feel_
Sep 23, 2015 09:06 PM
