STS turbo plus fuel problem
Old Jan 17, 2005 | 10:16 PM
Default STS turbo plus fuel problem
Installed sts turbo, 43lb injectors,Walbro intank pump and won't rev past 5000 rpm? sounds like rev limitor from 1-2 shift, then 4500 rpm from 2-3 shift sounds like rev limitor. Checked fuel pressure at idle 63lbs. wot drops to 49? any ideas please.
Old Jan 17, 2005 | 10:23 PM
badpewter-z's Avatar
LS1TECH Sponsor
stupid question but has it been tuned yet?
Old Jan 17, 2005 | 10:25 PM
BlownChevy's Avatar
blownerator
25 Year Member
Sounds like your in tank pump was not installed properly. I would drop the tank and verify the pump and FPR are seated correctly.
Yes it was tuned by Allen Nelson
Old Jan 17, 2005 | 10:27 PM
I guess I should start there as the fuel line came off the first time around then we put two clamps on it?
Old Jan 17, 2005 | 10:32 PM
BlownChevy's Avatar
blownerator
25 Year Member
Yeah it might be the place to start. Make sure everything is perfect. I know it is a pain in the a$$ but you need to make sure.
Old Jan 17, 2005 | 10:49 PM
I had my mechanic do the fuel pump, could you tell me what to look for if I decide to take a look myself.
5.3Okasai
Mar 9, 2022 01:07 PM
lxcoupe
Jul 21, 2015 02:12 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
Deceptarado
Jul 8, 2015 05:24 PM
