STS owners inside
Old Mar 18, 2005 | 11:39 PM
F8L Z71's Avatar
NP man
I couldn't being to est. how much boost you will see. Your motor is an enigma to me. I don't know any of the specs and even if I did I can not good enough to calc. how much boost you'll be able to run max. I'm sure Don is putting together a very efficient combo so you may not even see super high boost but you could make great HP.. The fact you are using a smaller motor though I would say you will probably see more boost than the rest of us. Kinda like no matter how efficient GNs or Supras are they still run MUCH higher boost #s than us V8s do.
I think you're going about it right. I'm just curious to see how that GT67 spools on your lil motor.
Old Mar 18, 2005 | 11:43 PM
8ALTNG's Avatar
Ya I was wonderin about the gt-67 on the "little motor" myself. But Don said it will be ok. So I guess it will be ok. With the right cam and once I scrape enough money together for some AFRs I should be fine
Old Mar 19, 2005 | 07:14 AM
jcfreak's Avatar
I'm running the base STS kit (60-1), 30lb injectors, and tune. Definately do the injector upgrade. I am running 8psi on mine with no meth or intercooler. I am putting the intercooler in today. There is a fuel system upgrade you can get through the STS dealers now. Its a fuel pump and 45lb injectors. Might want to check that out. I am also going to upgrade the turbo soon.
Old Mar 19, 2005 | 08:17 AM
quicksilverado's Avatar
Are your injectors maxed out at 8 psi? I have 33 lb injectors and they are maxed out at 5 psi.
Old Mar 19, 2005 | 11:18 AM
ltnklr~ what cam are you going with?
Old Mar 19, 2005 | 12:08 PM
8ALTNG's Avatar
Honestly I personally dont know. Don @ Dez racing says not to worry about it
Old Mar 19, 2005 | 02:00 PM
aight, well if you ever learn what it is let me know, cuz im going down the same route as you almost, except im having to start the project a little later this year.. i just dropped my money on lasik for my eyes
nabozny21
Oct 17, 2015 07:47 PM
SlvrSierra4.8
Oct 7, 2015 09:46 AM
turbo6c3
Oct 5, 2015 06:11 PM
