sts owners inside
Old Jan 26, 2005 | 11:27 AM
slowec's Avatar
Default sts owners inside
I have a 04 ec 5.3. I am considering the sts kit. What other parts are REALLY needed to comlete the install to have a dependable upgrade. i.e. injectors intercooler, or programming?Thanks, Rodney "slowec"
Old Jan 26, 2005 | 11:33 AM
F8L Z71's Avatar
You already mentioned them.
Injectors, fuel pump, intercooler OR meth, and a custom tune. A good boost controller can make life easy too.
I started with just meth and it works great but ended up getting the IC. I kinda needed it once power levels rose.
I would also set a goal for the truck and choose the turbo accordingly. Why waste another $700+ to upgrade the turbo later. Just get the GT67 now and deal with a lil lag till you get everything finished.
Old Jan 26, 2005 | 11:37 AM
chris99gmc's Avatar
F8L beat me to it, but I would have to reccommend doing the setup I just did.
Go for the bast kit. The Base turbo will be a decent choice, or you can spend the extra $$$ and upgrade to a bigger one. The bigger the turbo, the more high end pulling power there is, but on the other hand, it will lag more. I went with the gt-67 since my future motor mods will mate better with it.
Talk to Rick@Synergy... he now makes the FMIC kits for the STS... It comes with all the neccesary piping, clamps, fittings, and intercooler.
You'd need to get new injectors, a bigger fuel pump(I went w/ and in-line walbro 255), colder spark plugs, and a boost controller. A boost gauge and fule pressusre gauge are also good to have.
then get a custom tune. On the spot dyno tunes are the only way to go if you are doing a bigger power adder like this one.
Old Jan 26, 2005 | 11:46 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Amen. If you're going crazy, get the meth and the FMIC and then run 20psi
Old Jan 26, 2005 | 11:50 AM
F8L Z71's Avatar
Hey Erik. What injectors are you doing? I need to get something at least 60lb and I was pretty sure they would end up being F-bod style so the harness will have to be modified. Just wantd to make sure before I give Rick the goahead to order some.
You'll like my new setup. Not as cool as yours but for a budget I am hoping for low 11s.
Old Jan 26, 2005 | 11:55 AM
If you had sufficient injectors and fuel pump, what psi is the GT 67 good to on a 4.8 or has this frontier been tested yet with the sts?
Old Jan 26, 2005 | 12:03 PM
JERRY2500's Avatar
14 Second Truck Club
Damn you guys, I step away from my computer for 5 minutes and you got all the answers. And they got them all right. Yea, what they all said.
Old Jan 26, 2005 | 12:20 PM
You don't NEED any of those if you are going to leave it at 5 psi, although they would all be good. Of course, who is going to leave it at 5 psi???
Aaron
Old Jan 26, 2005 | 12:25 PM
JERRY2500's Avatar
Aaron
Boost controller on it's way as we speak.
Old Jan 26, 2005 | 12:29 PM
F8L Z71's Avatar
Tsk tsk tsk...... Jerry, what are you dooooooiiiiing?????
