STS help
Old Mar 14, 2005 | 11:21 PM
dennyb's Avatar
ok thats good to hear. now what about the actual turbo from the ground and driveshaft? does anyone have installed pics of their kits? its just that i have some stuff moved under the truck for the air ride.
Old Mar 15, 2005 | 12:33 AM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by dennyb
ok im new to increasing the performance of my truck. i want to get the sts kit for my 4.8 silverado auto trans. i was wondering what is exactly needed for this kit. i know it comes as a kit but im not sure if it has everthing i need for reliable use. eventually i will build the truck up, but for now ill be happy with the stock kit. do i need the fuel management, and injectors with the base kit. also what about the stock tranny will it be ok.
you can see what ive been doing to my truck up until nowTruck Pics
Or you could look into something lower profile and under the hood
Old Mar 15, 2005 | 01:23 AM
Green Thunder's Avatar
Somebody need to give Brian a ride in a turbo truck! (then he will send his resume to Garrett)
Old Mar 15, 2005 | 09:09 AM
Scott Mills's Avatar
Default STS Turbo
Have any of you with the turbo ever tried using a programer such as the Predator or Autotap to tune your trucks after the install?
Old Mar 15, 2005 | 09:24 AM
JERRY2500's Avatar
14 Second Truck Club
Yea i tryed the predator at first, Tuning realy sucked as far as for the turbo.
Old Mar 15, 2005 | 09:34 AM
ktmrider's Avatar
Talk to Chris99gmc, he is slammed with an STS kit. I believe he has posted some pretty good pics of his setup.
Nelson is the name thrown around the most, and I think he is recommended by STS for tuning. Like stated, tuning is REQUIRED, not optional.
The base turbo kit is probably good to 450 rwhp, and is really good for quicker spool. These big azz heavy trucks like the faster spool. F8L Z71 and others have upgraded to the 0.67 A/R ( stock is 0.60 A/R ) and are running sick times. OR you can copy Parish8 on his underhood setup and get into HotRod magazine!
Old Mar 15, 2005 | 09:44 AM
JERRY2500's Avatar
No doubt, Nelson is the only way to go.
Old Mar 15, 2005 | 10:07 AM
Weedo's Avatar
Or any shop that runs LS1 Edit or the like can do more of a custom tune while you're sitting on the dyno or logging on the street. And by "logging" I don't mean........
Old Mar 15, 2005 | 10:10 AM
JERRY2500's Avatar
That is correct
Old Mar 15, 2005 | 10:51 AM
MrXerox's Avatar
What are the specs on the turbo used in the base kit for STS and at what rpms does it begin and reach full boost on a stock 5.3?
