STS boost problem
Old Mar 25, 2005 | 10:33 AM
  #21
Wilde Racing's Avatar
How do I change this text
I got one more question, What does the STS kit (Tail) blow off valve sound like? I thought my was working un-tell some-one told me it sounded like "turbo bark".
Old Mar 25, 2005 | 01:43 PM
  #22
Weedo's Avatar
I have a blow-off valve (TiAL) in the engine bay, but when you hammer it and let off, the turbo makes a "woop-oooop-ooop" sound (like Curly/Mo). That always gets peoples attention!
Old Mar 25, 2005 | 03:47 PM
  #23
Cool thats what I'm hearing too, Thanks Weedo
Old Mar 29, 2005 | 06:08 AM
  #24
ktmrider's Avatar
Yep, it is kinda a neat sound. It is the pressure inside the intake tube feeding back on the compressor and slowing/stopping it from turning for a second or two. At high boost it can damage the turbo but overall causes it to slow down some. Bad if you are in traffic and go on-off-on, it will cause some lag and spool delays.
If you have the blowoff valve just adjust it to open a little sooner. Kinda tough tho if you are running a two stage controller.
Old Mar 29, 2005 | 02:09 PM
  #25
O.K to clear everything up (for me?). I took the truck out and drove it, turns out it does make about 6-7 psi with a few 8 psi spikes, the gauge was hooked up right the first time.
Well turns out there is a little arrow on the regulator for the boost controller, and if you hook it up wrong, you'r boost will spike and will have a higher overall boost presure.
Now if I could get my Air/Fuel ratio under control.
How would you adjust the Blow off valve to open sooner?
Old Mar 29, 2005 | 03:32 PM
  #26
TG02Z71's Avatar
You guys, I don't know if anyone has chimed in on the blow-off valve sound but the STS base kit comes with a wasegate only and it does make the woop-woop-woop sound when you back out of thr throttle under boost. However the wastegate is different than a blow-off valve. Just thought I'd throw this in to the disscussion.
Old Mar 29, 2005 | 08:09 PM
  #27
Both me and Weedo have a tail blow off valve "upgrade" I don't think mine is working
Old Mar 29, 2005 | 10:31 PM
  #28
jcfreak's Avatar
Did you run your vaccum line to the blowoff valve? If its not on there it want work.
Old Mar 29, 2005 | 11:00 PM
  #29
Ya I though I was saving time When I just "T"ed into my boost gauge and Alkycontrol M.A.P hoses. If that makes any cents, anyway the M.A.P's (and Blow off valve) only had 1/8 hose being supplied to them, I was told that the blow of needs at least 3/8 hose, so I got to hook the blow off valve to the brake booster supply hose to fix the problem.
Old Mar 30, 2005 | 02:33 PM
  #30
cdhd2001's Avatar
Just 5 lbs. boost? Weenies! I commonly see +35 lbs boost!
