STS boost problem
Old Mar 23, 2005 | 05:19 PM
Wilde Racing's Avatar
How do I change this text
Default STS boost problem
Well I finally got the kit installed were I could at least start the truck. The truck fired right up and ran a little ruff as the ECM was "learning", One small problem thou, NO BOOST. The electric boost gauge reads a vacuum and will go to 0 at high rpm but won’t go over 0 at all, maybe a bad gauge? Sounds sweet, And I can wait to drive it.
Thanks for any Ideas.
Old Mar 23, 2005 | 05:24 PM
jcfreak's Avatar
Check all your connectors on the piping and make sure they are all tight. If one blows of it will do that. Also if it is sitting idle and you rev it up you want see any boost.
Old Mar 23, 2005 | 05:30 PM
Ya I checked the piping already. any other Ideas?
Old Mar 23, 2005 | 05:38 PM
BigBlockChev572's Avatar
Philip S.
Old Mar 23, 2005 | 06:09 PM
Well I figured it out, Key off + for the boost calibration was not hooked up. Thank you jcfreak for the help.
Old Mar 23, 2005 | 06:24 PM
F8L Z71's Avatar
Originally Posted by BigBlockChev572
Philip S.
Yeah, the system has to be under load to see boost. Free reving really doesn't load the turbo enough to see positive pressure on the guage. Blowers are the same way.
Old Mar 23, 2005 | 06:57 PM
Yeah I understand that with very little Engine load the boost will be low, now that the gauge is set up right I think I'm going to have an over boost problem, Just rapping up the engine on the low waste gate setting I'm seeing about 8 pounds of pressure.
Old Mar 23, 2005 | 07:04 PM
F8L Z71's Avatar
Yikes, hehehe
Old Mar 23, 2005 | 07:07 PM
TURBHOE's Avatar
there only one way to find out go drive it!!
Old Mar 23, 2005 | 08:51 PM
bud8fan's Avatar
NO ...the boost should be 0 with no load not low boost...
