Stroker timing question
Old Sep 20, 2017 | 08:02 AM
Dangrebel's Avatar
Default Stroker timing question
hey guys, long time lurker. I have just put together a iron 408 stroker. ported 317's, 243/257 @.613 111lsa+3 custom spec btr cam, 10.8 to 1 comp. it may have been me getting used to the motor, however, it seemed to pull harder with less timing. I mean like 15 degrees WOT instead of 27 Degrees. Do the strokers require less timing to get to optimal timing? This weekend after i fix a dreaded header leak, i will play with the timing. Not sure if anyone has ran into this before. Thanks for the help!
Old Sep 20, 2017 | 08:49 AM
madmann26's Avatar
Spark timing is based on the efficiency of the cylinder heads. Less efficient, more timing, more efficient, less timing.
That's the funny thing with engines. Some like more timing, some like less.
Only way to be sure is to put it on a dyno.
Old Sep 20, 2017 | 09:14 AM
Dangrebel's Avatar
True, i wish i had a 4wd dyno around here that isnt almost 1g to get tuned on. I guess i could always pull the front driveshaft.
Old Sep 20, 2017 | 09:52 AM
03sierraslt's Avatar
What transfer case are you running.
Old Sep 20, 2017 | 09:53 AM
Dangrebel's Avatar
autotrac transfer case, not exactly sure the model number.
Old Sep 20, 2017 | 11:51 AM
Autotrac is selectable 4x4, are you 4x4 or AWD
Old Sep 20, 2017 | 12:41 PM
Dangrebel's Avatar
selectable 2hi, 4hi, 4lo, and auto.
I was told to not dyno this style case without having all 4 tires turning. Not sure if that is correct.
Old Sep 20, 2017 | 12:43 PM
Ist I’ve ever heard that for a selectable.
Old Sep 20, 2017 | 12:46 PM
Dangrebel's Avatar
I heard it was only for the autotrac and awd trucks. I never tried it, didnt want to risk it ha.
Old Sep 20, 2017 | 01:16 PM
Vortec350ss's Avatar
If youre in 2wd youre fine.
