Stripped threading on power steering pump
Old Apr 30, 2007 | 06:36 PM
Lurius's Avatar
Default Stripped threading on power steering pump
As title says, I stripped it, and have another 1/8th of an inch or so until the pulley is on fully. Any suggestions to get it on the rest of the way?
I have a BFH on standby if needed.
-Lurius
Old Apr 30, 2007 | 06:57 PM
ZZebes's Avatar
there i a special install took that grippy used
Old Apr 30, 2007 | 09:15 PM
Lurius's Avatar
Any other ideas? I'd like to get this thing road ready asap =)
Thanks guys,
-Lurius
Old May 1, 2007 | 09:44 AM
Lurius's Avatar
Bump.
-Lurius
Old May 1, 2007 | 09:46 AM
ReSpAwN DeMoN's Avatar
Get urself a hold of a tap and die set and make new threads.
Old May 1, 2007 | 10:03 AM
ThunderZ28's Avatar
12 Second Club
Tap the pulley back on with a mini Thor.
Been there done that..
Old May 1, 2007 | 01:02 PM
Lurius's Avatar
This wont damage the pump at all? My dad was helping me get it back on and said he thinks it would screw up the pump, I was all for the BFH though.
-Lurius
Old May 1, 2007 | 01:03 PM
blown3qtr's Avatar
could try a helicoil kit also.
Old May 1, 2007 | 01:18 PM
kbracing96's Avatar
Will the puller take the pulley back off? If so, pull it back off. Heat the pulley in the oven at around 400* or with a small torch till it's good and warm. It should slide right on, but be quick cuz if your not it will stick as it cools half way on.
Old May 1, 2007 | 06:10 PM
Lurius's Avatar
The torch did the trick! Its ready to start up once I get the PCM.
-Lurius
