Strenghtening stock rods and crank?
Old Feb 23, 2010 | 10:19 PM
SilvyBlack02's Avatar
Default Strenghtening stock rods and crank?
Just out of curiousity, is it posible to have the stock rods and crankshaft from an engine strengthend to withstand more abuse if there is no aftermarket rods/cranks?
Old Feb 23, 2010 | 10:20 PM
Dewey's Avatar
boil them in used motor oil maybe? i know that you can harden tools that way.
Old Feb 23, 2010 | 10:24 PM
hahaha, I assume any kind of good brand motor oil will do? boil at 400 degrees for how long?
Old Feb 23, 2010 | 10:35 PM
Mangled03gmc's Avatar
Baltimore Whore
You can have the crank polished, treated, have the rods shotpeened.. Peeing the stuff takes all the strees out of it.. However unless you plan on making 700+ hp with it, the crank is fine.. Cranks have been in 1000hp setups with no problems..
Old Feb 23, 2010 | 11:24 PM
Thanks, I'ts for the 4.3 giving it to a friend after the swap just wanted to know for his dumba$$ sake if they can be strenghtend. He's known for running WAY to much boost on his crap.
Old Feb 24, 2010 | 12:18 AM
Atomic's Avatar
I have a gauge for that
he will lift a head before he damages the crank
Old Feb 24, 2010 | 12:39 AM
james8997's Avatar
Atomic has a point, how often do you see a broken crank?
Old Feb 24, 2010 | 02:34 AM
99LsSilverado's Avatar
you can also do cryogenic treating for the parts
Old Feb 24, 2010 | 06:45 AM
EVILGMC's Avatar
plus 1 for cryo. i have had a lot of parts cryo treated...rotors, pads, tranny internals.
i bent a crank once.... .040 s curve in the bitch. hahaha
Old Feb 24, 2010 | 07:53 AM
Gordy M's Avatar
Years ago we used to bake the rods. Put them in the oven at 400 deg and bake them for 6-8 hrs. If you look is some old Peterson Hot Rod Chevy build books they had pics of them going into a kitchen oven.
