Strange misfire.....
Old Jul 23, 2006 | 01:44 PM
TravisH's Avatar
Default Strange misfire.....
Coming home late last night I was hauling *** on the freeway, and at WOT about 5500rpm my ses light started flashing so I let out of it and it kept flashing for awhile then turned off. I had my laptop in the truck, and hooked it up as soon as I got home and it was a p0300 or somthing like that.
Anyone have any Idea what caused this? I didnt hear anything strange, but I had the music on a little.
Old Jul 23, 2006 | 03:37 PM
chevymec's Avatar
is your laptop able to monitor all cylinders for misfires?? you might have to go out and drive it to look at what cylinder is missing. PO300 never tells you anything ither than there was a misfire.
Old Jul 23, 2006 | 03:45 PM
KY_BOB's Avatar
I've been fighting the same thing. I was blaming it on the meth injection till I did a log yesterday with " cylinder misfire" set as a pid on all 8 cylinders. Come to find out 95% of my "random cyl misfire" was coming from cyl #6. I haven't messed with it yet but I'm betting that I have a bad plug wire, even though I have a 1 year old set of Taylor TV50's.
Old Jul 23, 2006 | 08:53 PM
TravisH's Avatar
Yes I am capable of everything with the laptop, Ill have to take it out again and see if it happens. This was the first time its ever happened though.
Old Jul 23, 2006 | 09:26 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Check your injector wiring. I've had the same issue and it was always injector connections coming loose. Of course check the plugs and wires.
Old Jul 24, 2006 | 09:47 AM
TigerFan187's Avatar
For what its worth when I had a injector come unplugged **Shrugs shoulder** it through an injectors blah blah blah code.
On another note has anyone been experiencing some strange things with HPTuner V.2.12?
Old Jul 24, 2006 | 09:59 AM
I have had misfire issues from loose fitting plug wires on the plug end. Most connectors for the plug end do not fit very tight in the plug wires I've bought. I have started taking regular slip-joint pliers and squeezing the connectors just slightly in the open part of the pliers. Making them fit tighter has fixed some previous issues I have had.
Also, make sure you hear two audible clicks on the coil end of the wires when you put them on.
Old Jul 25, 2006 | 12:52 AM
TravisH's Avatar
Elaborate???
Old Jul 25, 2006 | 08:28 AM
slowec's Avatar
Plugged converters show up @ high rpm's. Something to check.
Old Jul 25, 2006 | 08:58 AM
Originally Posted by TravisH
Elaborate???
Im not trying to cause a scare ! We arent even certain yet and wont be untill tonite when we reload 2.10 and do some scanning/tuning but we are wondering about some readings/resultswe are getting. What made us even more confused is when a fellow tuner was having the same issues. Probably a glitch.
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
97_ek
Sep 23, 2015 09:16 PM
GMCtrk
Sep 11, 2015 09:04 AM
BennyB
Aug 1, 2015 08:48 AM
