stock lift and performance
Old Nov 30, 2004 | 05:43 PM
02sierraz71_5.3's Avatar
Default stock lift and performance
What is the purpose for having the rear 3 inches higher than the front on the stock setup. I plan on lifting the front 3" and the rear 1" will this effect performance noticably and will it level the truck.
I also plan on getting a higher stall will the stock x-mission cooler do a good job with a 3000 stall?
anybody have experience with gibsons super truck exhaust Im not happy with my 50 flow step up its not deep enough take a look at the pics I think the bend coming off the muffler might be inhibiting the sound
Attached Thumbnails stock lift and performance-bend.jpg   stock lift and performance-intake.jpg   stock lift and performance-tips.jpg   stock lift and performance-tips2.jpg
Old Nov 30, 2004 | 06:35 PM
do the leveling , then put 285 75 R16 BF goodrich all terrains trust me on this one it will look pimp ******* badass i have one to but 99 Z71 with leveling and 285 off roads f***** awesome its great if you offroad.
Old Nov 30, 2004 | 06:41 PM
Seeing Red Again's Avatar
So the truck can provide a nice comfy ride with leaf springs, yet still be able to tow and haul. You could have it sit level, but then it would dip the rear and raise the front when you loaded it down unless you had stiffer springs which causes a harsher ride.
Old Nov 30, 2004 | 07:16 PM
do what i said .
Old Dec 1, 2004 | 12:39 AM
Old Dec 1, 2004 | 12:44 AM
jow02327's Avatar
that is a pretty steap bend right after the muffler. try turning it down right after the muffler it will change the sound alot. mine had a similar set of bends so i turned it town and damb it sounds a lot better. you will get alot of sound back in the cab but hell i like it that away. plus it will blow the hell out of the ricers when you blow by them. me and nightmare did it to a supra at 110
Old Dec 1, 2004 | 01:05 AM
F8L Z71's Avatar
Just don't do it and then try to put a turbo on the truck and launch on high boost.
Then again, it makes for one hell of a bucking ride. LOL
5.3Okasai
Mar 9, 2022 01:07 PM
thunder550
Oct 8, 2015 04:53 PM
signguy62
Sep 20, 2015 02:05 PM
bgray
Jul 23, 2015 10:56 AM
cbhedrick
Jul 20, 2015 10:12 PM
