Stock heads for increased compression
Old Nov 24, 2006 | 01:50 AM
thunder550's Avatar
High on diesel fumes
Back the timing off a bit and run a 160* t-stat with the 34" rad he has and the efans to keep her nice and cool. Doubt he would be able to tow with that setup but he could try.
If it was me I would just the throw the heads from Richard on now since it would be alot easier now and driving a low 9:1CR wouldnt be to bad, and he could always throw some nitrous on it
Just trying to save a little bit of money right now....and I'll make a little more power too N/A.
You think I'd have problems towing with 9.6:1 on 91 octane?
Old Nov 24, 2006 | 01:52 AM
thunder550's Avatar
Damn those 243 heads are pricey
I think I'll just run my stock 317's for now, that would be cheapest. I'll be at 8.85:1 according to the Diamond compression calculator. Think that'll be ok, or is that getting to be too low?
4.03 bore
4.00 stroke
6.125 rods
4.125 gasket bore
.03 head gasket
9.23 deck height
.3 ring spacing from top of piston
72cc heads
28cc piston dish
.006 piston above deck height at TDC
Old Nov 24, 2006 | 09:12 AM
desTRUCKtive's Avatar
If you wanted to you can mill the 317 down about 30 thousanths and then put a thinner gasket and that will raise your compression a little.
Old Nov 24, 2006 | 11:22 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
If you are going to put 317s on there you might as well put Richards heads on there and save the trouble of dealing with a head swap in the truck. 9.6 should be fin, did you have detonation with the LQ9? If not I doubt you would with the 9.6.
Old Nov 24, 2006 | 11:35 AM
thunder550's Avatar
No, never had a problem with detonation.
Old Nov 24, 2006 | 09:42 PM
BigTex's Avatar
Exactly. Unless you plan in huge amounts of boost, then you'd be plenty safe going with a 9.5+ CR combo. The other part of that equation is the cam choice. Its pretty small for a 408 with boost. Your dynamic CR will be higher with a smaller cam.
Old Nov 25, 2006 | 02:49 AM
thunder550's Avatar
Looking into a bigger cam now. Might bump up the CR numbers too. We'll see.
GrooveCityZ71
Aug 31, 2015 12:05 PM
bbowerman
Jul 26, 2015 10:57 PM
sauldgold
Jul 23, 2015 02:15 PM
Suburban2500
Jul 19, 2015 04:50 PM
Aboss
Jul 9, 2015 10:28 AM
