Still have my low RPM ping!!!!!!!!!!!!
Old Apr 29, 2004 | 10:40 AM
Originally Posted by bigguy75inches
Its your rings,, your rings are blown, your motor puked its guts out. Well i hope not! hahah mine sure did though! lol oh well... its just bad gas
Speakin' of bad gas that Taco Bell last night/this morning F**ked me up!
Old Apr 29, 2004 | 11:43 AM
Have you checked your plugs ??
How they look ??
What plugs you running ??
I have seen pinging with Plat plugs as the tip remains hot and causes pre-ingition.
Old Apr 29, 2004 | 05:44 PM
99Silver6.0's Avatar
I went ahead and put the 99 timing tables back in earlier. Still fricking does it. I dont get it, maybe the resistors are causing problems. If I change out my PCM for say a 2001+ PCM I can send my Edit cables back to have them updated. But what do I do about my VIN matching up? If I get a 2002 PCM and put it in my truck will I have to do anything besides that VATS re-learn? Are the PCM's expensive?
LS1csherm,
Im running NGK TR55's. They look as good as they did when I put them in a month ago.
Old Apr 30, 2004 | 12:47 AM
HAZE's Avatar
pull your inj's and clean them or have them cleaned ? maybe they're dirty beyond the in tank stuff. just a thought.
Old Apr 30, 2004 | 02:51 AM
Procharged LM7's Avatar
Are you referring to the audible low rpm, loaded valvetrain chatter? Mine has doen it since brand new, and most of the ones I have seen do, too. Some are quieter than others.
Following Bob Prims method I found on Pacific Audio way back when I bought mine, I did the foam mod in the steering boot
I will spare the explanation of the mod to save myself from ridicule
If that is it, it is nothing but valvetrain noise from low rpm load.
Old Apr 30, 2004 | 06:35 AM
jlwz71's Avatar
I remember it was flower foam in the steering boot. The foam you use to make flower arraignments.
lucas287
31
Jan 12, 2021 06:18 AM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Texas5.3_1251
Mar 5, 2016 08:10 PM
b4z
Sep 10, 2015 06:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
