starting problems
Old Mar 13, 2003 | 11:45 PM
'992500silverado's Avatar
Default starting problems
hey has anyone out there ever had a problem with a delay in the starter engaging after you turn the ignition switch to the start position. Sometimes you may have to hold the key to the start position for 2 seconds before the starter will turn. Also the tach and speedo needles are sticking in spots while driving down the road.
Old Mar 14, 2003 | 08:44 AM
Buckwheat's Avatar
Default Re: starting problems
Sounds like the starter solenoid is going out. As far as the needles go, I would check the alignment of the instrument overlay. I've heard of people buying those fancy overlays for F-bodys on ebay and having problems with the needles doing what your describing. Probably just the speedo and tach shafts rubbing/sticking on the edge of the overlay.
ferrellrooster
Mar 6, 2025 03:22 PM
treylittlefield
Jan 24, 2016 07:38 PM
chevy6.0fan
Aug 20, 2015 07:10 PM
WarbirdLS1
Aug 8, 2015 10:53 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
