starting...or not
Old Dec 15, 2008 | 09:19 PM
joeyc125's Avatar
11 Second Truck Club
Default starting...or not
I am having problems starting my truck. I went out to start it the other night, and it barely turned over and then died. Dang, dead battery right? Tried jumping it, same thing. Brought battery back where i bought it, its a 2 month old optima red top, they tested it good. Dang, what else could it be besides the starter? replaced that, its original with 100k on it, still nothing. I turned the motor over by hand with a breaker bar and it seems fine, checked ground from battery to block, fine, checked connections, seemed ok, swapped relays, still nothing. all i am getting is a click from the solenoid and the starter gear popping to the flywheel. Anybody have any suggestions?? It won't even turn the motor.
Old Dec 16, 2008 | 11:23 AM
budhayes3's Avatar
PT's Slowest Truck
Check for a voltage drop across the battery cables, one at a time. They may look OK but could be corroded internally, and not allowing enough current to flow to the starter.
Old Dec 16, 2008 | 12:42 PM
joeyc125's Avatar
thats the only thing i think it could be, its a relatively simple circuit but im having a tough time with this one.
Old Dec 16, 2008 | 09:48 PM
Fireman31's Avatar
try a different battery if you are able to, I don't trust auto part store battery tests.......the possibility is still there that your battery is NFG
Old Dec 17, 2008 | 07:31 AM
Raffman's Avatar
Optima's do that, I'll never buy another one.
Old Dec 17, 2008 | 12:03 PM
joeyc125's Avatar
tried a newer one out out of my other truck, same thing. ill mess with the battery cable tonight if i get a chance
Old Dec 17, 2008 | 06:17 PM
Truckshop's Avatar
sounds like it needs a new starter. have someone hold the key and tap the starter with a hammer. if it spins it is bad.
Old Dec 17, 2008 | 06:50 PM
joeyc125's Avatar
its a brand new starter, doing the same thing the old one was, no change.
Old Dec 17, 2008 | 06:52 PM
00ChevyScott's Avatar
Wearin' da big hat
It's still doing it even after turning the motor by hand? That rules out a messed up flywheel I guess.
Hmmm.
Old Dec 17, 2008 | 06:59 PM
silverod's Avatar
I dont know joe but the oil in my truck is getting old and its too cold outside to do it out there so get the damn thing out of the garage so I can change it lol J/K
