Stall converter daily performance
#31
I just put a CVC made Trailblazer converter in my truck yesterday. I was given it for free from a guy who put a 4L80E in his truck and he only had about 500 miles on the converter. Motor is a 4.8 with a Comp XR265HR-14 cam. Gear ratio is 3.73 and stock height tires. So far I'm happy with it.
#33
While I'm driving around I'm thinking about gearing and what would suit my truck and driving best. Interestingly, I just did a 15 lap stock car driving event at a local short track, and noted that the car wasn't geared for the track at all. By the time the motor was getting happy, it was time to lift a and brake for the corner.
So, I'd like some feedback from guys with 4 series gears. What size tires, what type of driving and on what kind of roads, what kind of cruising rpm at highway speeds during freeway driving, and what effect on your fuel mileage if you made a gear change. Also, if you did make a gear change, what gears did you start with?
Based on my past experience with hot rods, I'm pretty much leaning towards 3.73, but the car I had with those gears had much shorter tires, so the same gears in this truck would be completely different!
This thread should probably be in a different forum than engine/exhaust performance at this point, but.....
#34
I have 3.73 gears and 245/75-16 tires. I towed my boat for the first time this weekend after all the changes and it towed great, especially using the Tow/Haul mode but it would even tow well no using that mode. I'm happy with the changes so far.
#35
At the very least get 3.90 gears, I would get 4.11 or 4.56. I have a Trailblazer SS that came with 4.11 and a 31" when I put my drag pack on I went to a 28" drag radial. I drive it everyday with that gearing and a Yank SS3600 stall converter. Your truck won't be as bad because you will be running a taller tire, but a 4.11 gears and 2500 to 2800 stall shouldn't even scare you a little.
#36
I put in a TB 11" in my 4L60e 5.3L truck. I loved it. Supposedly bumps stall into the 22-2400 range. Only issue is truck would roll back a bit on hills, and in the wet would spin tires in first all the time (austin has fairly slick asphalt). Really woke the truck up. It was a probuilt automatics stage 1.5 kit, with a stock engine.
walledition
Mar 23, 2016 12:47 AM
stylinfosho
Mar 8, 2016 10:24 PM
