Stall choice
Old Jul 22, 2017 | 12:29 AM
GM4.8's Avatar
Default Stall choice
Im finally warming up to the idea of adding a stall on my truck, i know nothing about stalls other than they make acceleration more efficiently.
Mods currently on my 08 4.8 single cab are long tubes, 373s , 112lsa 220/220 cam.
this is my Daily driver ,once in a while i will get on it, but other than that i drive normal lol
What stall would be ideal for my truck?
How much would my mpgs fall under normal driving with the stall?
i was leaning more of a stall in the 3200 range, any info on what brands are best?
Old Jul 22, 2017 | 09:18 AM
terravast4's Avatar
call one of our vendors to the right. Yank, Circle D. With your info they can help you pick the right converter for YOUR needs
Old Jul 22, 2017 | 11:36 AM
ezdaar's Avatar
Whats your rear gear ratio?
Old Jul 22, 2017 | 03:47 PM
Tig's Avatar
Tig
I agree with terra
ez,
3:73s
Old Jul 22, 2017 | 07:42 PM
01SilveradoJakee's Avatar
I have a circle d 3200a stall in my truck now and love it. Mines a 3200 rpm stall with my cam and its a good match. I would rec. Reaching out to the company who made that cam and see what size the recommend.
You MPG city will fall alot. I used to get 370 miles out of my 25 gallon tank. Now if im very easy im lucky to get 290 out of it.
Old Jul 22, 2017 | 08:33 PM
darkirish63's Avatar
Yeah, you really need a higher stall to let that can breathe. You'll be amazed at the difference a good stall and a tune are going to make on that 4.8.
Old Jul 24, 2017 | 10:57 AM
Like my 3200 from circle d in my yukon.
Old Jul 24, 2017 | 11:05 AM
Furflyinjim's Avatar
Just curious , what does a trail blazer converter stall at ?
Old Jul 24, 2017 | 10:09 PM
Braaap's Avatar
Im running a yank pro truck 3600 224/230
Very happy with it. RPM is always in the sweet spot.
Got a local trans shop to install the converter, corvette servo, and Transgo HD2 at the same time. made a really nice difference.
Old Jul 25, 2017 | 01:34 AM
ezdaar's Avatar
With your specs,
A custom PTC 3k on the tight side. <~~~
Or a circ d 2800.
