Stainless Works Headers?
Old Aug 3, 2007 | 12:32 PM
TurboJohn6's Avatar
Default Stainless Works Headers?
Does anyone have Stainless Works LT headers on their truck? I am thinking about buying a set (with cats & y-pipe) and would like to get any feedback about fitment, quality, or any other comments. I want to stay with cats so it is either the Stainless Works or the Dynatechs. I have a 2000 ECSB w/5.3 and 4wd if that makes any difference. Chime in and let me hear some opinions. Thanks!
Old Aug 3, 2007 | 04:17 PM
nightrunner's Avatar
Mr. Obvious
budhayes has them
Old Aug 3, 2007 | 04:34 PM
wkdivr's Avatar
I have a set on my 04 RCSB; 5.3, and I like em. The fit was pretty good, I have a lift, and when I did my install, I jacked the body up just to make it easier. I'm not a huge fan of the band clamps for sealing, and had to do quite a bit of fooling with them to get them to finally seal, but all is good now.
Old Aug 3, 2007 | 11:54 PM
tb8100's Avatar
clips of your SW/Magnaflow exhaust!!!!
Old Aug 4, 2007 | 12:01 AM
Bill Reid's Avatar
grippy has a set doesn't he? He did a custom exhaust off of them. I saw a bunch of pics of the install and it looked really good. Maybe give moregrip a PM...
Bill
Old Aug 4, 2007 | 07:51 AM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by nightrunner
budhayes has them
Yessir I do, and I'm very happy with them The right side was a little tight on the frame, but I was able to tweak it and now it's good. I was actually kind of a test vehicle to see if they'd fit the 99-02's, as the guys at SW weren't sure if they'd fit, but they knew that they fit the 03-06's. Well they fit great, and installation was a direct bolt in I was very pleased with the communication and customer service that I received also.
Here's some pics:
Old Aug 4, 2007 | 08:52 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I also have their headers in my turbo build. I installed them with the front of the truck on jackstands and put them in from underneath -- they slid right in.
Old Aug 5, 2007 | 07:52 PM
budhayes3's Avatar
PT's Slowest Truck
Almost forgot...I'm not sure if SW is offering their headers with provisions for EGR and/or AIR, they didn't when I got mine. My truck originally came with EGR from the factory, but since I swapped in an 02 PCM which is non-EGR, I was able to delete it (EGR). Not sure if your truck has AIR, but I'll just about guarantee that it has EGR from the factory.
Old Aug 6, 2007 | 12:42 PM
NegraRCSB2X4auto's Avatar
I have sw my left header rubs on my steering wheel shaft(or whatever the hell its called).
Old Aug 6, 2007 | 10:12 PM
DrX's Avatar
DrX
I am generally satisfied with mine.
Pass side was very tricky to get in on the AV. Removing the coil packs helped.
Still seems to have a pass side frame knock issue on left turns only. The clamps can dimple the tubes slightly, locking them together. So future disassembly might not be as easy as it looks.
