Stabbed the 8.1!!!
Old Jul 26, 2004 | 07:22 PM
Default Stabbed the 8.1!!!
Put a new cam in on sunday. What ficking bear. 12 hours of manual labor. But what a sweet sound that is when at idle. It is a xr 270 from comp cams.Thanks, Tierod on the Good deal for the cam. Can't really tell now still babying it.
Question is once this thing gets a tune, do think it will perform better? (stuipd?i know)
How much better?
Bascially, just wanted to embellish little. after having the 8.1 down to heads and block. putting back to together is kind of rewarding. And that nice loping idle. MMMM loping idle MMMM
Old Jul 27, 2004 | 11:11 AM
Tokez420's Avatar
get a sound clip of that!
Old Jul 27, 2004 | 11:18 AM
marc_w's Avatar
Nice. How much more involved was it over a LS1? Sounds like you needed to pull the intake.
Do the 8.1's run roller lifters?
Old Jul 27, 2004 | 12:16 PM
yes the intake had to come off. also they do run roller lifters. as for the sound clip, going to wait and get headers and some exhaust in the works.
Old Jul 27, 2004 | 02:21 PM
marc_w's Avatar
Cool.
What sized cam did you go with? 270 advertised works out to be about 216-220 at .050, right?
What lift and LSA is it running?
I'm curious because I hear a lot of people with strokers going huge on cams. They say the extra cubes will eat up the cams... I don't deny that, I just don't they will to the extent that they're adding duration and lift to their cams.
Old Jul 27, 2004 | 04:15 PM
Yelo's Avatar
my guess is that would be 270º @.050....big blocks run HUGE cams
Old Jul 27, 2004 | 05:10 PM
here the specs int and exh. lift at .510 gross this is same as stock lift
duration at .006 is int: 270 and exh: 276
.050 is int: 218 and exh:224
LSA is at 114
Old Jul 27, 2004 | 05:23 PM
Yelo's Avatar
boy...that seems like a REALLY small cam for a 496cid motor....I've run a cam bigger than that in a motor 146cid smaller and it was still VERY streetable
Old Jul 27, 2004 | 07:45 PM
Biggest one comp cams makes for the 8.1. There a little of stumble at throttle tip-in. once your rolling not to bad. It not huge by far, but is a daily driver. It idle at 550rpms, when the ac kicks on it almost dies. pickup does shake ever so slightly.
Still sounds cool!!!
Old Jul 27, 2004 | 08:22 PM
TieRod's Avatar
Hope you have all the fun that I did with that cam. Just remember it's a big block you don't have to have a big cam to make power.
Oobray
Jun 13, 2022 03:38 AM
Ammadien
Jul 22, 2015 08:50 PM
Hit Man X
Jun 3, 2003 02:52 AM
tbyrne
Nov 3, 2002 11:19 PM
