Spun main. Machine Shop or Swap
Old Apr 19, 2018 | 07:44 PM
Cadillac Edd's Avatar
Default Spun main. Machine Shop or Swap
Hey guys im in a bind. Just got my 900hp 80e built and spun main bearing on cammed LQ9. It was at low speed when this happen. Actually trans builder was going in reverse when this happend. Turns out Oil Pump failed amd caused this to happen engine locked up. Builder checked lifters, springs, pistons all good. Crank wouldnt turn until bearing was removed. So now im not sure if i need to take it to the machine shop or no. If so should i or should i just find another engine whats the best move. Not really looming into borong the engine or nothing. Anybody know prices machine shop charges?
Old Apr 19, 2018 | 07:47 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Depends on how bad the damage is to the block. If it's discolored and scared real bad, It's junk. You will have to get a new block.
If there is hardly any wear in the bore, They can clean it up with a line hone.
Old Apr 19, 2018 | 07:48 PM
so in other words it still will need to see a machine shop?
Old Apr 19, 2018 | 07:52 PM
1FastBrick's Avatar
I can't see the damage. But to answer your question, Yes. The line bore will need to be checked.
That does not mean it needs to be bored out.
Old Apr 19, 2018 | 07:54 PM
which would you do? I got a guy that wants to sell me a lq9 long block for $1200.
Old Apr 19, 2018 | 07:57 PM
1FastBrick's Avatar
If it's easier to slap back together for you at $1200 then do that. Who's paying for the repair?
I am more than capable of building one from scratch, so if the block is still good I disassemble and have the machine shop look at it first and fix if possible. If not or more to fix than a replacement, I get a replacement.
Old Apr 19, 2018 | 08:02 PM
im paying for it. This one guy said he will charge $1200 to rebuild and labor it and $1200 for the machine shop to repair the block if damaged
Old Apr 19, 2018 | 08:06 PM
1FastBrick's Avatar
$1200 to repair the block??? That's insane!!!
If the line bore needs a clean up it shouldn't run more than like $150.
If your not tearing it down and there doing it, then that could be why its so high.
Old Apr 19, 2018 | 08:08 PM
ummm so i need to just call a machine shop my self to get a price.
Old Apr 19, 2018 | 08:12 PM
1FastBrick's Avatar
I would. for $1200 you can get another engine.
Hell they sell those block new now and there around $1600 for brand new block
